NetGear ProSAFE Click Switch 8PT GE
LIFETIME WARRANTY
Quicklinx: B29YWS00 Mfr#: GSS108E-100EUS
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
£61.49 ex VAT
£73.78 inc VAT
Your ports, where you want them
Today's networks have increasing numbers of devices attached to them. As wired devices proliferate, it can be difficult to easily and neatly place networked ports where you want them.
NETGEAR ProSAFE Click Switches™ address this issue head on.
These innovative Gigabit Ethernet switches come with an industry-first, bracket mounting system for easy installation. With a flexible and unique 1-2-3-4 click arrangement, it's easier than ever to enable optimal placement and cable management in locations where other switches will not go.
Vertical/side mount, Vertical/rear mount, Horizontal/side mount and Horizontal/rear mount.
  • Available in either 8- or 16-Gigabit port configurations
  • Slim design with internal power supplies
  • Sleek cable management system
  • USB charging ports on GSS108E
  • Prioritise and manage bandwidth usage with intuitive web browser as seen on the ProSAFE Plus series
Put an end to unsightly cables and switch placement challenges. Deliver a better way for customers to put their ports, where they want them. Available now, click here for your Click Switch from authorised NETGEAR channels.
NETGEAR Click GSS108E Smart Managed Plus - switch - 8 ports - smart
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
Virtual interfaces (VLANs): 64 , Layer 2 multicast groups: 128
MAC Address Table Size
8K entries
Jumbo Frame Support
16KB
Remote Management Protocol
HTTP
Flow control, VLAN support, IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, full duplex mode, firmware upgradable, vertical mounting, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), horizontal mounting, plastic housing, fanless, DHCP client, Energy Efficient Ethernet, 2MB packet buffer, loop prevention, Multicast filtering function, Class of Service (CoS), tagged VLAN, Type of Service (ToS), DiffServ Code Point (DSCP) support
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
30.5 cm x 6.5 cm x 3.5 cm
440 g
United Kingdom, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
8K entries
Jumbo Frame Support
16KB
HTTP
Status Indicators
Port transmission speed, power, link/activity
8 x 1000Base-T RJ-45 , 2 x USB (power only) Type A
Internal power supply
20.1 Watt
Cable retaining straps, 1-2-3-4 mounting kit
MTBF
1,031,177 hours
CISPR 22 Class B, cUL, EN 60950, IEC950, UL 1950, CSA 22.2 No. 950, EN50082-1, EN55022 Class B, C-Tick Class B, FCC Part 15 B, EN55024 Class B, CCC Class B, VCCI Class B
Software Included
Drivers & Utilities
30.5 cm
6.5 cm
3.5 cm
440 g
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
B29Y C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
B29Y C2G 5m USB 2.0 A/B Cable - Black In Stock £5.00
B29Y C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.51
B29Y C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.40
Ports: 8
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: 50 - 100
