Product
NetGear ProSAFE Click Switch 16PT GE
Lifetime warranty
Quicklinx: B29ZWS00 Mfr#: GSS116E-100EUS
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
23 in stock
£128.80 ex VAT
£154.56 inc VAT
Your ports, where you want them
Today's networks have increasing numbers of devices attached to them. As wired devices proliferate, it can be difficult to easily and neatly place networked ports where you want them.
NETGEAR ProSAFE Click Switches™ address this issue head on.
These innovative Gigabit Ethernet switches come with an industry-first, bracket mounting system for easy installation. With a flexible and unique 1-2-3-4 click arrangement, it's easier than ever to enable optimal placement and cable management in locations where other switches will not go.
Vertical/side mount, Vertical/rear mount, Horizontal/side mount and Horizontal/rear mount.
  • Available in either 8- or 16-Gigabit port configurations
  • Slim design with internal power supplies
  • Sleek cable management system
  • Prioritise and manage bandwidth usage with intuitive web browser as seen on the ProSAFE Plus series
Put an end to unsightly cables and switch placement challenges. Deliver a better way for customers to put their ports, where they want them. Available now, click here for your Click Switch from authorised NETGEAR channels.
NETGEAR ProSafe Click GSS116E - switch - 16 ports - Managed
Switch - 16 ports - Managed
Ports
16 x 10/100/1000
Performance
Bandwidth: 32 Gbps
Virtual interfaces (VLANs): 128 , Layer 2 multicast groups: 128
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Remote Management Protocol
TFTP
Flow control, network monitoring, trunking, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, full duplex mode, vertical mounting, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), horizontal mounting, Jumbo Frames support, fanless, Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, loop prevention, Multicast filtering function, tagged VLAN, 4MB packet buffer, metal housing, Type of Service (ToS), DiffServ Code Point (DSCP) support
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3az
7 cm x 40.7 cm x 3.5 cm
1.3 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop
Ports
16 x 10/100/1000
Performance
Bandwidth: 32 Gbps
8K entries
Jumbo Frame Support
9KB
TFTP
Status Indicators
Port transmission speed, power, link/activity
16 x 1000Base-T RJ-45
Internal power supply
8.4 Watt
Cable retaining straps, 1-2-3-4 mounting kit
MTBF
721,479 hours
VCCI, C-Tick, cUL, EN 60950, EN55022, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, CISPR 22, EN50082-1, CCC, FCC Part 15
Europe
Software Included
Drivers & Utilities
7 cm
40.7 cm
3.5 cm
1.3 kg
Limited warranty - lifetime , Limited warranty - power supply - 2 years
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
B29Z C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
B29Z C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.19
B29Z C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.64
B29Z C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £45.36
Ports: 16
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: 100 - 150
