Product
Brand
NetGear ProSafe Auxillary Power Supply for GSM72xxPS
Quicklinx: BYL1WS00 Mfr#: APS525W-10000S
The ProSafe Auxiliary Power Supply APS525W provides a replaceable power supply for the select gigabit switches. You can make use of an RPS (Redundant Power Supply) while replacing the power supply. When an RPS is used, the power supply can be replaced without stopping the switch or requiring a reboot.
NETGEAR Prosafe APS525W Auxiliary Power Supply - power supply - hot-plug - 525 Watt
Power supply - hot-plug - plug-in module
1.9 kg
Power Capacity
525 Watt
19.4 cm x 21.6 cm x 42.4 cm
ProSAFE GSM7228PS, GSM7252PS
Power Capacity
525 Watt
50 °C
10 - 90%
19.4 cm
21.6 cm
42.4 cm
1.9 kg
NETGEAR ProSAFE GSM7228PS, GSM7252PS
