NetGear Prosafe 8-Port Plus Switch
Lifetime warranty
Quicklinx: 9S0BWS00 Mfr#: GS108E-300UKS
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 1Gbps
Managed: No
POE: No
More than 50 in stock
£31.48 ex VAT
£37.77 inc VAT
At NETGEAR the importance of a stable and robust network infrastructure is understood. ProSAFE products are designed to exceed the high standards required of business-class network.
NETGEAR Plus GS108Ev3 - switch - 8 ports
Switch - 8 ports
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
VLANs supported: 32
Network monitoring, VLAN support, IGMP snooping, DoS attack prevention, Broadcast Storm Control, Quality of Service (QoS), bandwidth control, loop prevention
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z
15.8 cm x 10.1 cm x 2.9 cm
540 g
Microsoft Windows Vista / XP / 7
United Kingdom
NETGEAR lifetime warranty
Switch - 8 ports
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
VLANs supported: 32
8 x 1000Base-T RJ-45
External power adapter
MTBF
2,525,259 hours
Plug and Play, C-Tick, VCCI Class B ITE, CISPR 22 Class B, EN 60950, EN55022 Class B, CB, FCC Part 15 B
United Kingdom
Software Included
Drivers & Utilities
15.8 cm
10.1 cm
2.9 cm
540 g
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
Ports: 8
Managed: No
POE: No
Brand: NETGEAR
Price Range Ex VAT: 0 - 50
