The Next-Gen Edge M5300 series switches are NETGEAR top of the line Gigabit stackable fully managed switches for modern access layer in campus and enterprise networks with 10 Gigabit Ethernet backbone requirements. The M5300 series delivers pure line-rate performance for virtualization or convergence. NETGEAR Next-Gen Edge solutions combine latest advances in hardware and software engineering for higher availability, stronger security, better scalability, and even more energy efficiency (1.5W per port line-rate traffic for 48+4 port versions).
- Netgear Next-Gen Edge Managed Switch M5300-52G - switch - 48 ports - rack-mountable
- Switch - 48 ports - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 44 x 10/100/1000 + 4 x combo SFP + 2 x combo SFP/SFP+
- Performance
- Bandwidth: 184 Gbps
- MAC Address Table Size
- 32K entries
- Jumbo Frame Support
- 12KB
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SSH, SSH-2
- Flow control, Layer 2 switching, BOOTP support, ARP support, IGMP snooping, Syslog support, DiffServ support, MAC address filtering, Broadcast Storm Control, SNTP support, Weighted Random Early Detection (WRED), Spanning Tree Protocol (STP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), SSH support, DHCP server, MLD snooping, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, DHCP client, Multicast VLAN Registration (MVR), Ring Rapid Spanning Tree Protocol (RRSTP), Class of Service (CoS)
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3ak, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az
- 44.5 cm x 39.2 cm x 4.2 cm
- 6.9 kg
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 32K entries
- 12KB
- Encryption Algorithm
- TLS 1.0, SSL 3.0
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Status Indicators
- Port status, power, link/activity
- 44 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x 100Base-TX/1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 2 x 10Gb Ethernet / 1Gb Ethernet - RJ-45 , 2 x 10Gb Ethernet / 1Gb Ethernet - SFP+ , 1 x console - mini-USB Type B , 1 x console - 9 pin D-Sub (DB-9) , 1 x USB Type A
- Power Device
- Internal power supply
- Installed Qty
- 1
- 79 Watt
- Rack Mounting Kit
- Included
- CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, FCC Part 15 A, C-Tick Class A
- 44.5 cm
- 39.2 cm
- 4.2 cm
- 6.9 kg
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
