NetGear ProSafe 24-port Next-Gen Edge Managed Switch
LIFETIME WARRANTY
Quicklinx: 8SGPWS00 Mfr#: GSM7228S-100NES
The NETGEAR Next-Gen Edge M5300 series consists of three fully managed, stackable Gigabit Ethernet switches, with embedded 10 Gigabit Ethernet uplink connectivity. There are 24-port and 48-port models including Gigabit copper versions, and a Fiber aggregation solution. They are ideal for all organizations considering reliable, affordable and simple 10 Gigabit Ethernet backbone architectures. As a proficient component of converged voice, video and data networking solutions, NETGEAR M5300 series delivers a resilient access layer in server rooms for virtualization, campus LAN environments and commercial buildings. Virtual Chassis stacking technology - including meshed stacking - scales both the entire network's performance and its redundancy.
Netgear Next-Gen Edge Managed Switch M5300-28G - switch - 24 ports - rack-mountable
Switch - 24 ports - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
20 x 10/100/1000 + 4 x combo SFP + 2 x combo SFP/SFP+
Performance
Bandwidth: 136 Gbps
MAC Address Table Size
32K entries
Jumbo Frame Support
12KB
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SSH, SSH-2
Flow control, Layer 2 switching, BOOTP support, ARP support, IGMP snooping, Syslog support, DiffServ support, MAC address filtering, Broadcast Storm Control, SNTP support, Weighted Random Early Detection (WRED), Spanning Tree Protocol (STP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), SSH support, DHCP server, MLD snooping, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, DHCP client, Multicast VLAN Registration (MVR), Ring Rapid Spanning Tree Protocol (RRSTP), Class of Service (CoS)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3ak, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az
44.5 cm x 39.2 cm x 4.2 cm
6.3 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Bandwidth: 136 Gbps
32K entries
Jumbo Frame Support
12KB
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
Status Indicators
Port status, power, link/activity
20 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x 100Base-TX/1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 2 x 10Gb Ethernet / 1Gb Ethernet - RJ-45 , 2 x 10Gb Ethernet / 1Gb Ethernet - SFP+ , 1 x console - mini-USB Type B , 1 x console - 9 pin D-Sub (DB-9) , 1 x USB Type A
Internal power supply
Installed Qty
1
55 Watt
Rack Mounting Kit
Included
CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, FCC Part 15 A, C-Tick Class A
44.5 cm
39.2 cm
4.2 cm
6.3 kg
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
8SGP C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
