Product
Brand
NetGear ProSafe 24-Port Gigabit PoE L2 + Managed Switch
Lifetime warranty
Quicklinx: 7VQRWS00 Mfr#: GSM7228PS-100EUS
NETGEAR Stackable, PoE Managed Gigabit switch GSM7228PS allows the most flexible and easy-to-deploy Gigabit Power over Ethernet infrastructure. All the 24 ports of 10/100/1000 Mbps interfaces support 802.3af PoE standard with a comfortable 384 watts total budget. Two built-in 10 Gigabit Ethernet SFP+ interfaces on the front and two additional 10 Gigabit module bays on the rear, permitting both uplinks and local/distant stacking, provide versatile 10 Gigabit deployment possibilities.
Combining superior resiliency, enterprise-class security and non-blocking performance, NETGEAR Stackable PoE Managed Gigabit switch GSM7228PS offers a full set of layer 2 management features, as well as layer 2+ (layer 3 lite - IPv4 routing) with unsurpassed affordability. The GSM7228PS series can be deployed at enterprise edge, remote branch offices and closer to the core of small and medium businesses' growing networks.
NETGEAR ProSAFE GSM7228PS - switch - 24 ports - Managed
Switch - 24 ports - L2+ - Managed - stackable
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 (PoE) + 4 x shared SFP + 2 x SFP+ + 8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
384 W
Performance
Non-blocking backplane speed: 144 Gbps , Throughput: 107.1 Mbps
MAC Address Table Size
8K entries
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2, CLI
Flow control, Layer 2 switching, power over Ethernet (PoE), BOOTP support, ARP support, trunking, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, manageable, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, IPv6 support, High Availability, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, Dynamic ARP Inspection (DAI), PoE+
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1v, ANSI/TIA-1057, IEEE 802.1ab (LLDP)
44 cm x 39.1 cm x 4.3 cm
6.3 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
384 W
Performance
8K entries
Max Units In A Stack
8
Routing Protocol
Static IP routing
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1: 666 MHz
RAM
256 MB
Flash Memory
32 MB Flash (Firmware)
Status Indicators
Port transmission speed, power, link OK, status, link/activity
16 x 1000Base-T RJ-45 PoE , 1 x serial (RS-232) DB-9 management , 4 x Gigabit LAN SFP , 2 x 10Gbit LAN SFP+ , 8 x 1000Base-T RJ-45 PoE+ - 30 W
Expansion Slots
2 (total) / 2 (free) x Expansion Slot
Redundant Power System (RPS) connector
1 x null modem cable
Rack Mounting Kit
Included
MTBF
211,069 hours
CISPR 22 Class A, EN 60950, IEC950, UL 1950, VCCI Class A ITE, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, FCC Part 15 A, C-Tick Class A
Europe
Software Included
Drivers & Utilities
44 cm
39.1 cm
4.3 cm
6.3 kg
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
7VQR C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.16
7VQR C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.25
7VQR C2G 2m Cat6a Shielded Patch - Blue In Stock £7.00
7VQR C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £43.89
