The ProSafe FS116P provides power and data from a single point, using Power over Ethernet (PoE) over a single Cat-5 cable. The sixteen Fast Ethernet ports can be used for any 10/100 Mbps link and eight of these ports can supply industry-standard IEEE 802.3af power. Advanced auto-sensing algorithm gives power only to 802.3af end devices, so no need to worry about damaging proprietary PoE or non-PoE equipment. In addition, it discontinues the power when PoE devices are disconnected. Easy and reliable, the ProSafe FS116P automatically determines PoE requirements, speed, duplex, and cable type using AutoUplink.
The affordably priced ProSafe FS116P delivers PoE to any small business network that wants to simplify the installation of wireless access points and IP-based surveillance cameras. These devices are optimally installed on a ceiling or high on a wall, away from most electrical outlets. PoE eliminates the requirement for a dedicated electrical outlet to power these devices. This allows for flexibility in situating devices where AC power is difficult to access and lowers installation costs. Compact and flexible, the ProSafe FS116P is ideal for small business network that want to inexpensively use PoE to deploy wireless access points and IP-based network surveillance cameras.
Choose to plug in up to eight Ethernet or Fast Ethernet devices and mix in up to four 802.3af IP-based devices like wireless access points or IP-based network surveillance cameras. Place these 802.3af-compliant devices where they belong - high up on walls and ceiling for maximum coverage - or anywhere else you need them. Power and data are carried over standard Cat-5 cabling.
The standards-based ProSafe FS116P senses and adjusts for network speed and cabling type automatically, for easy integration into your existing 10/100 Ethernet network. For PoE, the switch automatically detects 802.3af-compliant devices, and supplies power as needed. Front panel LEDs keep you informed of switch and PoE status.
Engineered for compact convenience, it is only 1-inch high and 4-inches deep, with a durable metal case that is easily positioned on your desktop or a wall, using the included mounting hardware. The fan-less design quietly integrates in your small office environment.
With data switching and Power over Ethernet integrated into one unit, the FS116P saves space, reduces cables and eliminates the requirement for dedicated electrical outlets - lowering installation costs, simplifying installation of PoE-capable devices, and eliminating the need for electricians or extension cords. All in all a great benefit for a modest price.
Flexible
Choose to plug in up to 16 Ethernet or Fast Ethernet devices and mix in up to eight 802.3af IP-based devices like wireless access points or IP-based network surveillance cameras. Place these 802.3af-compliant devices where they belong - high up on walls and ceiling for maximum coverage - or anywhere else you need them. Power and data are carried over standard CAT-5 cabling. -
Plug and Play
The standards-based ProSafe FS116P senses and adjusts for network speed and cabling type automatically, for easy integration into your existing 10/100 Ethernet network. For PoE, the switch automatically detects 802.3afcompliant devices, and supplies power as needed. Front panel LEDs keep you informed of switch and PoE status. -
Quiet and compact
Engineered for compact convenience, it is only 1-inch high and 4-inches deep, with a durable metal case that is easily positioned on your desktop or a wall, using the included mounting hardware. The fan-less design quietly integrates in your small office environment. -
Great value
- NETGEAR FS116Pv2 - switch - 16 ports - unmanaged
- Switch - 16 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100 (PoE)
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 70 W
- Performance
- Bandwidth: 3.2 Gbps
- MAC Address Table Size
- 8K entries
- Flow control, auto-sensing per device, store and forward, Energy-Efficient Ethernet (EEE)
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x
- 28.6 cm x 10.2 cm x 2.7 cm
- 830 g
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100 (PoE)
- PoE
- PoE Budget
- 70 W
- Performance
- 8K entries
- Status Indicators
- Power, PoE, link/activity/speed
- 16 x 100Base-TX RJ-45 PoE
- Power Device
- External power adapter
- 80 Watt
- Included Accessories
- Wall mounting kit
- MTBF
- 546,673 hours
- Plug and Play, EN 60950, EN55024, FCC Part 15 A, C-Tick Class A, LVD, VCCI Class A, EN 55022/CISPR 22 Class A, IEEE 802.3az
- Localisation
- Europe
- 28.6 cm
- 10.2 cm
- 2.7 cm
- 830 g
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
- 0 °C
- 40 °C
- 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £10.22 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £5.84 |
