From the lobby to the storage room, Orbi Pro Tri-Band Wi-Fi System (SRK60) covers up to 5,000 square feet with high-performance AC3000 (3Gbps) Wi-Fi. First with innovative Tri-band Wi-Fi, Orbi Pro helps deliver the fastest available Internet speeds as more devices connect. This Orbi Pro Wi-Fi system comes with an Orbi Pro Wi-Fi router and satellite and replaces your business router. It also easily works with existing business service provider equipment so you will enjoy better Wi-Fi everywhere in your business.
Fast business Wi-Fi everywhere
From the lobby to the storage room, Orbi Pro Tri-Band Wi-Fi System (SRK60) covers up to 5,000 square feet with high-performance AC3000 (3Gbps) Wi-Fi. First with innovative Tri-band Wi-Fi, Orbi Pro helps deliver the fastest available Internet speeds as more devices connect. This Orbi Pro Wi-Fi system comes with an Orbi Pro Wi-Fi router and satellite and replaces your business router. It also easily works with existing business service provider equipment so you will enjoy better Wi-Fi everywhere in your business. -
Ethernet ports
Use the Ethernet ports on the router and the satellite to connect your point of sale, printer, IP phones and more. -
Traffic separation
Up to 3 Wi-Fi Internet networks (SSID) with traffic separation to define 3 dedicated and completely isolated Wi-Fi networks inside your company securely. SSID management is easily done through the Orbi app for instant setup.
- NETGEAR Orbi Pro SRK60 - Wi-Fi system - Wi-Fi 5 - desktop, wall-mountable, ceiling-mountable
- Wi-Fi system
- Enclosure Type
- Desktop, wall-mountable, ceiling-mountable
- Wi-Fi System Components
- Router, extender
- Wi-Fi System Coverage
- Up to 5,000 sq.ft
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz (1 band) / 5 GHz (2 bands)
- Captive Portal, MU-MIMO technology, beamforming technology, Tri-Band, guest access
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- 17.3 cm x 8.38 cm x 24.6 cm
- 934 g
- Wi-Fi system - 7-port switch (integrated)
- Router, extender
- Up to 5,000 sq.ft
- Enclosure Type
- Connectivity Technology
- Wireless, wired
- Frequency Band
- Encryption Algorithm
- WPA, WPA2-PSK
- Wi-Fi Rating
- AC3000
Line Properties
- Line Coding Format
- 256 QAM
- WAN: 1 x 1000Base-T - RJ-45 , LAN: 3 x 1000Base-T - RJ-45 , LAN: 4 x 1000Base-T - RJ-45 - on extender
Aerial
- Aerial
- Internal
- Antenna Qty
- 6
- Power Device
- External power adapter
- Installed Qty
- 2
- Included Accessories
- 2 x wall mounting kits, 2 x ceiling mounting kits
- Cables Included
- 1 x network cable - 2 m
- 17.3 cm
- 8.38 cm
- 24.6 cm
- 934 g
