NETGEAR Orbi Mini Router + Mini Satellite
Quicklinx: CZPYWS00 Mfr#: RBK40-100UKS
  • IEEE 802.11n
£218.71 ex VAT
£262.45 inc VAT
Orbi by NETGEAR is a Whole Home WiFi System that delivers stronger, faster Wi-Fi throughout your home. From the basement to the backyard, this Orbi WiFi System (RBK40) covers up to 4,000 square feet with high performance AC2200 Wi-Fi. First with innovative Tri-band Wi-Fi, Orbi helps deliver the fastest available Internet speeds even as more devices connect. This Orbi WiFi System comes with an Orbi Wi-Fi Router and Satellite and replaces your home router and extenders. It easily works with existing Service Provider equipment so you'll enjoy better Wi-Fi everywhere. Connect more wired devices using the 4 Ethernet ports on the Orbi Satellite.
NETGEAR Orbi WiFi System RBK40 - Wi-Fi system - 802.11a/b/g/n/ac - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
Router, extender
Wi-Fi System Coverage
Up to 4,000 sq.ft
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands) / 5 GHz (3 bands)
MU-MIMO technology, beamforming technology, guest access
16.3 cm x 7.87 cm x 20.3 cm
748 g
Wi-Fi system - mesh - 3-port switch (integrated)
Router, extender
Up to 4,000 sq.ft
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Encryption Algorithm
WPA2-PSK
Wi-Fi AC Rating
AC2200
Mesh Networking
RAM
512 MB
Flash Memory
4 GB
Line Properties
Line Coding Format
256 QAM
Internet of Things (IoT)
Intelligent Assistant Compatible
Alexa
WAN: 1 x 1000Base-T - RJ-45 , LAN: 3 x 1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
1 x network cable - 2 m
16.3 cm
7.87 cm
20.3 cm
748 g
Type: Wi-Fi system
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Brand: NETGEAR
Price Range Ex VAT: 150 - 300
