NETGEAR Orbi Kit 1Router + 2Satellite Bndl
Quicklinx: CZQ1WS00 Mfr#: RBK53-100UKS
  • IEEE 802.11n
£419.11 ex VAT
£502.93 inc VAT
* This high-performance Whole Home Mesh WiFi System covers large homes up to 5,000 sq ft with fast WiFi. System includes a WiFi router and one satellite.*
Easy Setup and Use with the Orbi App
With the Orbi app, setup takes just minutes, so you can start enjoying better WiFi sooner. You can also see your connected devices, run an internet speed test, manage your NETGEAR service subscriptions, and more from the palm of your hand.
  • Single network name
    Simple or creative Wi-Fi name and seamless roaming for your whole home to enjoy.
  • Max internet speeds
    Innovative Tri-band Wi-Fi helps deliver fast Internet speeds even as more devices connect.
  • Your home and yard
    Cover your home and yard with high performance Wi-Fi.
  • Simple and secure
    Use the Orbi app or a web browser to create secure whole home Wi-Fi in minutes. With no accounts to setup.
NETGEAR Orbi WiFi System RBK53 - Wi-Fi system - Wi-Fi 5 - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
Router, 2 extenders
Wi-Fi System Coverage
Up to 7,500 sq.ft
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands) / 5 GHz (3 bands)
Intelligent Assistant
Alexa
MU-MIMO technology, beamforming technology, guest access, Circle Smart Parental Controls
16.3 cm x 7.87 cm x 20.3 cm
889 g
Wi-Fi system - mesh - 3-port switch (integrated)
Router, 2 extenders
Up to 7,500 sq.ft
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Encryption Algorithm
WPA2-PSK
Wi-Fi Rating
AC3000
Mesh Networking
RAM
512 MB
Flash Memory
4 GB
Line Properties
Line Coding Format
256 QAM
Internet of Things (IoT)
Alexa
WAN: 1 x 1000Base-T - RJ-45 , LAN: 3 x 1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
1 x network cable - 2 m
16.3 cm
7.87 cm
20.3 cm
889 g
Type: Wi-Fi system
Standards: IEEE 802.11n
Standards: IEEE 802.11a
Standards: Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11ac
Speed: 3Gbps
Brand: NETGEAR
