Meet Orbi – Fast, Secure, Whole Home WiFi
Orbi is the World’s First Tri-band WiFi System. From your front yard to your home office to your pool, Orbi gives you reliable, secure, and crazy fast WiFi to every inch of your home.
WiFi Everywhere
No more dead zones upstairs, no dropped connections through walls, just WiFi everywhere. The Orbi Home WiFi System reaches up to 4,000 square feet through WiFi barriers like walls, stairs and doors. Need more coverage? Just add an Orbi Satellite to instantly expand your WiFi reach.
Don’t Wait on Buffering
Buffering shouldn’t be a part of family movie night. Orbi helps prevent buffering and lag by creating a high speed Internet superhighway for all of your devices. The Orbi Tri-band WiFi System works with your current ISP’s modem to maximize the speed you are paying for.
Quick and Easy Setup
Unlike some WiFi systems, Orbi works with your Internet service provider right out of the box. You won’t need to change your current equipment to use the Orbi WiFi Home System. Orbi uses a single WiFi name (SSID) and with just a couple of clicks, your secure WiFi network will be ready in no time.
Routers. Not Just for Squares Anymore
Orbi’s sleek design and state-of-the-art technology steals the show. It gives your home a superior WiFi network that is both easy to setup and elegant to display.
Better Wi-Fi, everywhere
Take your Wi-Fi device from room to room and Orbi follows with the fastest Wi-Fi speeds possible. -
Your Wi-Fi system starts here
Orbi Router is the heart of the Orbi Wi-Fi System. It covers up to 2,000 sq. ft with high-performance AC3000 Wi-Fi. -
Just plug in
With simple setup from your mobile device, your secure Wi-Fi network is ready in just minutes.
- NETGEAR Orbi Router (RBR50) - wireless router - Wi-Fi 5 - desktop
- Wireless router - 3-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz (1 band) / 5 GHz (2 bands)
- Data Transfer Rate
- 3 Gbps
- TCP/IP, PPTP, PPPoE, DHCP, SMB, DDNS
- Routing Protocol
- RIP-1, RIP-2
- DHCP support, IPv6 support, parental control, Access Point operational mode, firmware upgradable, WPA2 encryption, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), port forwarding, reset button, MU-MIMO technology, WPA encryption, Circle Smart Parental Controls
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- 17.03 cm x 7.89 cm x 22.58 cm
- 890.5 g
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 3 Gbps
- Routing Protocol
- RIP-1, RIP-2
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, C-Tick, EN55022 Class B, VCCI Class B, FCC Part 15 Class B
- RAM
- 512 MB
- Flash Memory
- 4 GB
- Status Indicators
- Power, status
Line Properties
- Line Coding Format
- 256 QAM
- LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Antenna Qty
- 6
- Power Device
- External power adapter
- Cables Included
- 1 x network cable - 2 m
- 17.03 cm
- 7.89 cm
- 22.58 cm
- 890.5 g
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
