NETGEAR Nighthawk Pro AC2600 WiFi Router
Quicklinx: DB9KWS00 Mfr#: XR500-100EUS
  • IEEE 802.11n
£230.04 ex VAT
£276.04 inc VAT
XR500 Nighthawk Pro Gaming Wi-Fi Router uses state-of-the-art software to optimize your internet connection by stabilizing ping, reducing lag spikes, and keeping you in the game with reliable wired and wireless connectivity for fast-paced gaming. Personalize your gaming dashboard to view real-time bandwidth utilization by device, ping and many other parameters. Limit lag and get a guaranteed local connection with Geo Filter or enable Quality of Service for prioritized gaming devices and allocated bandwidth.
  • Multi-user MIMO (MU-MIMO)
    Traditional Wi-Fi routers can stream data to only one device in the home at a time. When multiple devices are connected to the router, each device needs to take its turn, and then wait before receiving more data. This can lead to slower network and Internet speeds. Using Multi-User MIMO technology, NETGEAR routers can stream data to multiple devices simultaneously. With MU-MIMO, your Wi-Fi network can deliver faster throughput to every MU-MIMO connected device. That means faster downloads and smoother streaming for your devices.
  • Beamforming+ - for more reliable connections
    Unlike typical Wi-Fi routers that just blast the Wi-Fi signals in all directions, with Beamforming+ the router & device communicate with each other, so the router can directly beam the Wi-Fi signal to the device. Boosting speed, reliability, and range for both Implicit and Explicit 2.4 & 5 GHz Wi-Fi devices, the result is a stronger, faster, more reliable connection that is locked in even when the device is moved around the home.
NETGEAR Nighthawk Pro Gaming XR500 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
NAT support, SPI, DoS attack prevention, IPv6 support, QoS, ReadySHARE, Push ā€˜N’ Connect button, Beamforming+, MU-MIMO technology, LED on/off button
32.19 cm x 24.37 cm x 5.5 cm
801 g
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC2600
1.7 GHz
RAM
512 MB
Flash Memory
128 MB
Line Properties
Line Coding Format
256 QAM
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
1 x network cable
Software Requirements
Internet Explorer 11 or later, Microsoft Edge, Google Chrome 55 or later, Mozilla Firefox 45 or later, Safari 10 or later
32.19 cm
24.37 cm
5.5 cm
801 g
Type: Wireless router
Standards: IEEE 802.11g
Standards: Gigabit Ethernet
Standards: Ethernet
Standards: IEEE 802.11b
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Brand: NETGEAR
