Get fast speeds with the NETGEAR AC1900 Wi-Fi Nighthawk VDSL/ADSL modem router. Enjoy the ultimate in Wi-Fi speeds up to 1.9Gbps and a powerful dual core 1GHz processor for extreme performance. High-powered amplifiers, external antennas and Beamforming+ improve range and reliability. Nighthawk supports ADSL/ADSL2/ADSL2+ and VDSL/VDSL2.
Wi-Fi ADSL/VDSL modem router
Get the superfast Wi-Fi speeds of up to 1.9Gbps. Supports ADSL/ADSL2/ADSL2+ and VDSL/VDSL2 with auto detection for Universal DSL support. Compatible with any Internet service provider with via the Gigabit Ethernet WAN port. -
Streaming and gaming
Enjoy buffer-free streaming and gaming with Nighthawk AC1900 Wi-Fi ADSL/VDSL Modem Router. A powerful dual core 1GHz processor and Wi-Fi speeds up to 1.9Gbps keeps you connected to speed while the advanced QoS prioritizes gaming and streaming so other connected devices won't slow you down. Features like two USB 3.0 ports allows you even more convenient and quicker streaming from the router-connected USB drive. Nighthawk also offers secure remote access to your home network via VPN. -
Mobile
Improve your connection throughout your home while on new or legacy mobile devices. Roam farther and maintain your speed and reliability with Beamforming+ and powerful external antennas. -
Speed
Get the fastest Wi-Fi currently available and enjoy a blazing-fast, lag-free Wi-Fi experience for gaming, video streaming or surfing. -
Wi-Fi range
Got range? Homes come in all shapes and sizes and the Nighthawk AC1900 Wi-Fi ADSL/VDSL modem router provides Wi-Fi coverage no matter where you connect in your home. -
Reliability
There's nothing more frustrating than lost connections! With NETGEAR's advanced features and best-in-class technology, you'll reduce interference and enjoy more reliable Wi-Fi connectivity.
- NETGEAR Nighthawk - wireless router - DSL modem - Wi-Fi 5 - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, VDSL, ADSL2, ADSL2+, VDSL2
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1900 Mbps
- FTP
- Firewall protection, auto-sensing per device, NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Wireless Guest Services, FTP server, ReadySHARE, Push ‘N’ Connect button, 3T3R MIMO technology, Beamforming+
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- 28.5 cm x 18.5 cm x 5 cm
- 750 g
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/8.1
- Localisation
- United Kingdom
- 1-year warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1900 Mbps
- FTP
- Encryption Algorithm
- WPA-PSK, WPA2-PSK
- Processor
- 1 GHz
- RAM
- 256 MB
- Flash Memory
- 128 MB
Line Properties
- Line Coding Format
- 256 QAM
Communications
- DSL modem
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A , Phone line: 1 x VDSL2 / ADSL2+ - RJ-11
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Power Device
- External power adapter
- Included Accessories
- POTS filter
- Cables Included
- 1 x network cable , 1 x phone cable
- Localisation
- United Kingdom
- OS Required
- 28.5 cm
- 18.5 cm
- 5 cm
- 750 g
- Limited warranty - 1 year
