NETGEAR Nighthawk AC1900 WiFi LTE Modem Router
Quicklinx: CDWSWS00 Mfr#: R7100LG-100EUS
  • IEEE 802.11n
£279.87 ex VAT
£335.84 inc VAT
Got game? Well, this is the router for you! Built with gaming, streaming and mobile devices in mind, this Gigabit Wi-Fi router has a powerful processor and delivers extreme speed, so you enjoy less lag and less buffering. With Beamforming+ and built-in high-powered amplifiers and external antennas, get ready for the extreme!
  • Built for gaming, streaming and mobility
    NETGEAR Nighthawk AC1900 Wi-Fi router was built to handle all your high-bandwidth online activities with features, that will keep you connected at top speeds. With the powerful processor and advanced upstream QoS for game consoles, Nighthawk can prioritize bandwidth to your game, so other devices on the network don't slow down your connection. Nighthawk also has downstream QoS and is optimized for streaming different applications, so you can enjoy uninterrupted video streaming with limited buffering. And with features, like high performance external antennas, and Beamforming+, you can enhance your mobile speeds so you can roam freely throughout your home without fear of slow or dropped connections.
  • Simple and secure cloud storage
    Access and share your files stored on a USB drive through NETGEAR ReadyCLOUD USB access. Simply plug your USB hard drive into your NETGEAR Nighthawk Wi-Fi router to create secure personal cloud storage. Enjoy the convenience and accessibility without the fees, storage limitations, or privacy concerns. Using the ReadyCLOUD, you'll now have anytime, anywhere access to your USB drive at home... it's that easy!
NETGEAR Nighthawk AC1900 - wireless router - WWAN - Wi-Fi 5 - desktop
Wireless router - wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Mobile Communication Protocol
LTE
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1900 Mbps
Firewall protection, NAT support, VPN support, SPI, IPv6 support, parental control, QoS, WPS, ReadySHARE, Push ‘N’ Connect button, Circle Smart Parental Controls
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED, IEEE 802.11ac
30.61 cm x 26.16 cm x 20.32 cm
1.125 kg
Europe
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1900 Mbps
Encryption Algorithm
WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1900
1 GHz
RAM
256 MB
Flash Memory
128 MB
Communications
Wireless cellular modem
LTE
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A
Expansion Slots
1 (total) / 1 (free) x Micro-SIM
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
1 x network cable - 1.5 m
Europe
Software Included
NETGEAR Genie
30.61 cm
26.16 cm
20.32 cm
1.125 kg
CDWS C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
CDWS C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.13
Type: Wireless router
Standards: IEEE 802.11n
Standards: IEEE 802.11a
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11ac
Speed: 1900Mbps
Brand: NETGEAR
