Your basket is empty
NetGear Nighthawk AC1900 Smart WiFi Router - Dual Band Gigabit
Quicklinx: 98CDWS00 Mfr#: R7000-100UKS
Type: Wireless router
Connection Type: DSL (Cable)
Standards: IEEE 802.11n
Speed: 1900Mbps
Rackmount or External: External
  • Windows 8.1 (32/64 bits)
  • IEEE 802.11n
Hurry, only 1 left in stock!
£120.14 ex VAT
£144.16 inc VAT
Enjoy lag-free gaming with the ultimate in AC speed & performance. Nighthawk delivers AC1900 WiFi, a powerful dual core 1GHz processor, & advanced upstream QoS for optimized game play on consoles like the XBox. When microseconds count, let Nighthawk accelerate your game. For the win. Stop buffering and start enjoying uninterrupted streaming media with features like downstream QoS, Beamforming+ and built-in iTunes server you'll begin to stream like you mean it. Access your stored media quickly with USB 3.0 and keep it safe with free automatic backup software for PCs & Time Machine compatible for Macs. Improve your mobile WiFi speeds by up to 100% with Nighthawk! High-powered amplifiers & antennas help extend WiFi coverage throughout large homes & even backyards. Beamforming+ focuses WiFi signals to WiFi devices. With signals locked onto your device, experience what it really means to be mobile!
NETGEAR R7000 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Firewall protection, NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), FTP server, ReadySHARE, Apple Time Machine compatible
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED, IEEE 802.11ac
28.5 cm x 18.45 cm x 5 cm
750 g
Microsoft Certification
Compatible with Windows 7
UNIX, Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Vista, Windows 8, Windows 8.1 (32/64 bits)
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
1 GHz
RAM
256 MB
Flash Memory
128 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 2.0: 1 x 9 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
1 x network cable
United Kingdom
Software Included
NETGEAR Genie
28.5 cm
18.45 cm
5 cm
750 g
98CD C2G 2m USB 2.0 A/B Cable - Black In Stock £3.24
98CD C2G 5m USB 2.0 A/B Cable - Black In Stock £4.73
98CD C2G 2-Port USB 2.0 Manual Switch In Stock £19.58
98CD C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.67
98CD C2G 4-Port USB 2.0 Aluminum Hub In Stock £26.28
98CD C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.93
98CD C2G USB Superbooster Extender Kit In Stock £34.64
98CD C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £36.76
Speed: 1900Mbps
Brand: NETGEAR
Price Range Ex VAT: 100 - 150
