NETGEAR Nighthawk 5-Stream AX4200 (RAX43) WiFi 6 Router
Quicklinx: GCZHWS00 Mfr#: RAX43-100EUS
  • IEEE 802.11n
£211.27 ex VAT
£253.52 inc VAT
The NETGEAR Nighthawk AX5 5-Stream AX4200 Wi-Fi Router provides speeds up to 4.2Gbps so you can connect, stream, and download faster to newer mobile devices.
Delivering four times better performance than AC Wi-Fi, Wi-Fi 6 allows more devices to connect and stream simultaneously, without impacting speed or reliability, by efficiently packing and scheduling data.
With innovative technologies, such as Orthogonal Frequency-Division Multiple-Access (OFDMA) and intelligent scheduling, Wi-Fi 6 delivers a huge boost in speed and total capacity.
NETGEAR Nighthawk AX5 RAX43 - wireless router - Wi-Fi 6 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Streams: 5
Intelligent Assistant
Google Assistant, Alexa
NAT support, VPN support, Stateful Packet Inspection (SPI), DFS support, firmware upgradable, Beamforming+, guest access, NETGEAR Armor, Voice Control, 4K UHD video streaming, 160MHz bandwidth support
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
29.58 cm x 20.6 cm x 5.72 cm
566 g
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
United States
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Streams: 5
Encryption Algorithm
WPA, WPA2, 128-bit AES, WPA2-PSK, WPA3
Wi-Fi Rating
AX4200
1.5 GHz
RAM
512 MB
Flash Memory
256 MB
Line Properties
Line Coding Format
256 QAM, 1024 QAM, OFDMA
Internet of Things (IoT)
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
External
Antenna Qty
4
External power adapter
1 x network cable
United States
29.58 cm
20.6 cm
5.72 cm
566 g
Limited warranty - 1 year , Technical support - 90 days
Type: Wireless router
Standards: IEEE 802.11n
Standards: Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Standards: IEEE 802.11ax (Wi-Fi 6)
Brand: NETGEAR
