Superior 802.11ac performance with an affordable price point
The NETGEAR WAC120 Wireless Access Point is a cost effective, high performance dual band 802.11ac AP supporting up to an aggregate throughput of 1.2 Gbps (300 Mbps for 2.4 GHz and 867 Mbps 802.11ac for 5 GHz). WAC120 802.11ac AP operates in standalone mode with an intuitive user interface and a flexible desktop mounting stand. It is perfectly positioned for customers demanding high throughput, ultra superior performance, and extensive coverage deployment for Small and Home Office environments.
High performance dual band 802.11ac wireless access point
Deliver the cost effective solution for Small Office and Home Office
Industry leading performance and value with 1.2 Gbps of wireless throughput
NETGEAR reliable 3 year product warranty
Flexible deployment with simplicity in management
Small offices with a single WAC120 to provide maximum throughput for the entire premise
Dental offices with a few WAC120 to provide ubiquitous coverage with strong receptions
Small hospitalities such as Bed and Breakfast for ease of setup and reliable connectivity
Gigabit Wireless Connectivity for Small Office and Home Office
Support up to 1.2 Gbps (867 Mbps at 5 GHz and 300 Mbps at 2.4 GHz) of wireless throughput
Gigabit wired connectivity to Internet gateway routers or cable modems
Dual band concurrent operation at both 2.4 and 5 GHz frequency range
Simple connectivity and ease of set up
Connect simply to DSL gateway, routers, or cable modems
WAC120 802.11ac Access Point provides high performance gigabit wireless
Wireless Protected Setup (WPS) button enables ease of client auto configuration
- NETGEAR WAC120 - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0), IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- 17 cm x 18 cm x 6 cm
- 322 g
- 3-year warranty
- 17 cm
- 18 cm
- 6 cm
- 322 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1.2 Gbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, status, LAN, wireless
- Auto-uplink (auto MDI/MDI-X), MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), Wireless Client Mode
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- Authentication Method
- Basic Service Set Identifier (BSSID)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna
- Internal
- Gain Level
- 2 dBi
- 1 x 1000Base-T - RJ-45
- Cables Included
- 1 x network cable
- Power Device
- External power adapter
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
