The NETGEAR PLW1000 AV 1000 Powerline/HomePlug Starter Kit can use your existing electrical wiring to extend your WiFi and Internet access to any room in your house. Just plug a Powerline Adapter into your modem or router, then plug in the companion Powerline WiFi access point to an electrical outlet. It’s that easy. With 1000 Mbps speed and Homeplug AV2 support, the NETGEAR PLW1000 is perfect for connecting smart TVs, streaming players, and game consoles wirelessly.
- NETGEAR Powerline PLW1000 - powerline adapter kit - Wi-Fi 5 - wall-pluggable - with NETGEAR PowerLINE 1000 Adapter (PL1000)
- Powerline adapter kit - with NETGEAR PowerLINE 1000 Adapter (PL1000)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV) 2.0, IEEE 1901, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1 Gbps
- IEEE 802.3, HomePlug AV 2.0, IEEE 1901
- Power
- AC 120/230 V
- 8.7 cm x 3.8 cm x 12.1 cm
- 266 g
- System Requirements
- Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
- Localisation
- United Kingdom
- 1-year warranty
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1 Gbps
- 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV 2.0
- Power Device
- Internal power supply
- Voltage Required
- AC 120/230 V
- 5 Watt
- Cables Included
- 2 x network cable - 2 m
- Localisation
- United Kingdom
- OS Required
- 8.7 cm
- 3.8 cm
- 12.1 cm
- 266 g
- Limited warranty - 1 year , Technical support - 90 days
