NetGear M7100-24X 24-port 10-Gigabit ProSAFE L2+ Managed Switch
LIFETIME WARRANTY
Quicklinx: 8GXLWS00 Mfr#: XSM7224-100NES
Type: 10 Gigabit Ethernet
Ports: 24
Data Transfer Rate: 10Gbps
Managed: Yes
POE: No
£1,903.06 ex VAT
£2,283.67 inc VAT
The M7100-24X is a state-of-the-art, high-performance, IEEE-compliant network switch. It includes powerful management features that you can use to eliminate bottlenecks, boost performance, and increase productivity.
This switch can be free-standing or rack-mounted in a wiring closet or an equipment room.
NETGEAR ProSAFE M7100-24X - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 100/1000/10000 + 4 x 10 Gigabit Ethernet / 1 Gigabit Ethernet SFP+
Performance
Bandwidth: 480 Gbps
Virtual interfaces (VLANs): 1000
MAC Address Table Size
32000 entries
Jumbo Frame Support
12KB
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2
IGMP snooping, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, LLDP support
IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az
44 cm x 43 cm x 4.3 cm
Enclosure Type
Desktop, rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
Bandwidth: 480 Gbps
32000 entries
Jumbo Frame Support
12KB
Authentication Method
RADIUS, TACACS+
24 x RJ-45 , 4 x 10Gb Ethernet / 1Gb Ethernet - SFP+ , 1 x console - 9 pin D-Sub (DB-9) , 1 x console - mini-USB Type B , 1 x USB - 4 pin USB Type A
300 Watt
FCC Class A certified, C-Tick, cUL, VCCI Class A ITE, UL 60950, CB, CCC
Software Included
Drivers & Utilities
44 cm
43 cm
4.3 cm
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
8GXL C2G 2m USB 2.0 A/B Cable - Black In Stock £3.63
8GXL C2G 5m USB 2.0 A/B Cable - Black In Stock £5.26
8GXL C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.83
Ports: 24
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: 1500+
