NETGEAR M4300-96X Managed Switch 48xSFP+ APS600W Starter Kit
Quicklinx: DF3YWS00 Mfr#: XSM4396K1-100NES
Type: 10 Gigabit Ethernet
Ports: 48
Managed: Yes
£8,410.52 ex VAT
£10,092.62 inc VAT
The NETGEAR M4300-96X is a 2RU modular switch that comes either empty or pre-populated with 48 SFP+ ports and supporting up to 96-port 10GBASE-T copper (RJ-45) with first 48 ports capable of PoE+, 96-port 10GBASE-X fiber (SFP+), 24-port 40GBASE-X fiber (QSFP+), or a combination. The M4300 family provides world-class services for server and storage interconnect, mid-enterprise edge and SMB core. SDVoE-Ready, M4300 switches streamline AV-over-IP deployments with Zero Touch multicast. Layer 3 feature set includes static, policy-based and dynamic routing as standard.
NETGEAR M4300-96X - Starter Kit - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
48 x 10 Gigabit SFP+
Performance
Switching capacity: 1.92 Tbps , Throughput: 2.857 Mpps , 10 Gbps fibre latency (64-byte packets): 0.75 µs , 10 Gbps fibre latency (512-byte packets): 1.17 µs , 10 Gbps fibre latency (1024-byte packets): 1.603 µs , 10 Gbps fibre latency (1518-byte packets): 1.97 µs
Virtual interfaces (VLANs): 4093 , IPv4 routes (static): 64 , IPv6 routes (static): 64 , RIP routes: 512 , ARP entries: 8000 , OSPF routes: 12000 , NDP entries: 8000
MAC Address Table Size
256K entries
Jumbo Frame Support
9KB
Routing Protocol
OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, HTTPS, SSH, CLI
Modular design, ARP support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, Remote Switch Port Analyzer (RSPAN), Per-VLAN Rapid Spanning Tree (PVRST), dynamic ARP protection, Neighbor Discovery Protocol (NDP), IP source guard, Bridge protocol data unit (BPDU), LISP Across Subnet Mode (ASM), Source-Specific Multicast (SSM), 96MB packet buffer
IEEE 802.3ad (LACP), IEEE 802.3az, IEEE 802.1AX
AC 120/230 V
53.5 cm x 44 cm x 8.8 cm
16.28 kg
Europe, Americas
ProSAFE lifetime warranty
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
Performance
256K entries
Jumbo Frame Support
9KB
Max Units In A Stack
8
Routing Protocol
Authentication Method
RADIUS, TACACS+
1: 1.4 GHz
RAM
2 GB
Flash Memory
256 MB
1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A , 48 x 10GBase-X SFP+
Expansion Slots
12 (total) / 6 (free)
Internal power supply
Installed Qty
1
Max Supported Qty
2
Power Provided
600 Watt
AC 120/230 V
566 Watt
6 x I/O module blank slot covers
1 x mini-USB type B to USB type A power cable , 1 x console cable
Rack Mounting Kit
Included
BSMI, EN 60950, UL 1950, IEC 60950, CB, FCC CFR47 Part 15, LVD, RCM, BSMI CNS 14336-1, EN 61000-3-3:2013, YD/T993-1998, EN 61000-3-2:2014, CNS 13438 Class A, GB 4943.1-2011, EN 55032:2012+AC:2013 Class A, ANSI C63.4-2014, ISED, ICES-003:2016 issue 6 Class A, CISPR 32:2012, VCCI-CISPR 32:2016 Class A, AN/NZS 60950.1:2015, AS/NZS CISPR32:2013 Class A, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 55024:2010 Class A, T9254-2008 (Class A), EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Europe, Americas
53.5 cm
44 cm
8.8 cm
16.28 kg
Limited warranty - lifetime
50 °C
95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 48
Managed: Yes
Brand: NETGEAR
Price Range Ex VAT: £1500+
