NETGEAR M4300-28G-POE+ Managed Switch APS550W
Quicklinx: C4YGWS00 Mfr#: GSM4328PA-100NES
Type: 10 Gigabit Ethernet
Ports: 28
Managed: Yes
POE: PoE+
29 in stock
£1,153.70 ex VAT
£1,384.44 inc VAT
The NETGEAR M4300 Switch Series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB aggregation deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series. Non-stop forwarding virtual chassis architecture provides advanced High Availability (HA) with hitless failover, that is, distributed link aggregation allows for load balancing and virtually zero downtime. License-free L3 feature set includes static routing, policy-based routing, RIP, VRRP, OSpiv as well as Multicast PIM routing. The NETGEAR M4300 Switch Series is ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
M4300-28G-PoE+ comes with 24 ports 1G PoE+ capable of full provisioning, 2 ports 10GBASE-T and 2 ports 10GBASE-X SFP+ in a full-width form factor. All 4 ports 10G are independent and can be used for stacking or uplinks: they are 1G backward compatible. In this GSM4328PA version, M4300-28G-PoE+ is delivering resilient and secure access layer in campus LAN environments and commercial buildings. Ideal for wireless access, unified communications and IP video applications: 480W PoE budget is provided by one APS550W PSU. A second one will add 1+1 power redundancy in RPS mode, and extended 720W PoE budget in EPS shared mode.
  • Outstanding stacking
    M4300 is flexible enough for mixed stacking between 10 Gigabit and 1 Gigabit models, using any 10G port with any media type (RJ45, SFP+, DAC cables) High-availability is another key differentiator for stackable solutions: in case of a master switch failure, NSF and hitless failover ensure the standby switch takes over while forwarding plane continues to forward traffic on the operational stack members without any service interruption.
  • Higher flexibility
    Two half-width M4300 switches can be paired in a single rack space for redundant Top of Rack installations with Auto-iSCSI prioritization. 10 Gigabit ports are all independent and 1G backward compatible for progressive transition to 10G speeds.
  • Investment protection
    Line-rate spine and leaf stacking topologies offer multiple possibilities in server rooms, in branch collapsed cores or at the edge of growing networks. Even if an organization is not ready for SDN, OpenFlow support offers future-ready design for maximum investment protection.
  • Secure services
    With successive tiering, the Authentication Manager allows for authentication methods per port for a tiered authentication based on configured time-outs.
  • Industry standard management
    Industry standard command line interface (CLI), functional NETGEAR web interface (GUI), SNMP, sFlow and RSPAN. Single-pane-of-glass NMS300 management platform with centralized firmware updates and mass-configuration support.
NETGEAR ProSAFE M4300-28G-PoE+ - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
2 x 10/100/1000/10000 + 2 x 10 Gigabit SFP+ + 24 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
480 W
Performance
Switching capacity: 128 Gbps
Routing Protocol
OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, CLI
ARP support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, front to back airflow, STP Root Guard, IPv4 support, LACP support, DHCP relay, Remote Switch Port Analyzer (RSPAN), Per-VLAN Rapid Spanning Tree (PVRST), dynamic ARP protection, IP source guard, Bridge protocol data unit (BPDU), LISP Across Subnet Mode (ASM), Source-Specific Multicast (SSM)
IEEE 802.3ad (LACP), IEEE 802.3az
AC 120/230 V
Europe, Americas
NETGEAR lifetime warranty
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
PoE+
PoE Budget
480 W
Performance
Max Units In A Stack
8
Routing Protocol
Authentication Method
RADIUS, TACACS+
2 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A , 24 x 1000Base-T RJ-45 PoE+
Internal power supply
Installed Qty
1 (installed) / 2 (max)
Power Provided
550 Watt
AC 120/230 V
Europe, Americas
Limited warranty - lifetime
C4YG C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
C4YG C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.19
C4YG C2G 2m Cat6a Shielded Patch - Blue In Stock £7.20
Ports: 28
Managed: Yes
POE: PoE+
Brand: NETGEAR
Price Range Ex VAT: 1000 - 1500
