Product
Netgear M4100-50G-PoE+ Managed Switch
Quicklinx: 8M60WS00 Mfr#: GSM7248P-100NES
Type: Gigabit Ethernet
Ports: 50
Data Transfer Rate: 1Gbps
Managed: Yes
POE: PoE+
£870.42 ex VAT
£1,044.50 inc VAT
Intelligent Edge M4100 series consists of 12 fully managed switches ranging from 8-port Fast Ethernet to 50-port Gigabit Ethernet. They are ideal for all organizations considering reliable, affordable and simple access layer switching with CLI scripting, Layer 3 static routing as well as PoE scalability. As a cost-effective component of converged voice, video and data networking solutions, NETGEAR M4100 series delivers a secure, intelligent edge in commercial buildings and large campus LAN environments. PoE (802.3af) and PoE+ (802.3at) versions of M4100 series are perfect for Wireless access points, IP telephony, CCTV and video-surveillance deployments.
NETGEAR ProSAFE M4100-50G-PoE - switch - 50 ports - Managed - rack-mountable
Switch - 50 ports - L2+ - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
50 x 10/100/1000 + 4 x shared SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
380 W
Performance
Bandwidth: 100 Gbps
MAC Address Table Size
16K entries
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, CLI
Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, RADIUS support, MLD snooping, IPv4 support, LACP support, DHCP client, Multicast VLAN Registration (MVR), Class of Service (CoS)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
44 cm x 31 cm x 4.32 cm
4.96 kg
Canada, United States, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
380 W
Performance
Bandwidth: 100 Gbps
16K entries
Routing Protocol
Static IPv4 routing
Authentication Method
RADIUS, TACACS+
Status Indicators
Port status, power, RPS (Redundant Power Supply), PoE, fan
48 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC) , 1 x USB - 4 pin USB Type A , 1 x console - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin mini-USB Type B
Internal power supply
555.5 Watt
Redundant Power System (RPS) connector
Rack Mounting Kit
Included
CISPR 22 Class A, cUL, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, CB, CCC, FCC Part 15 A, C-Tick Class A
Software Included
Drivers & Utilities
44 cm
31 cm
4.32 cm
4.96 kg
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
8M60 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.84
8M60 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.98
8M60 C2G 4-Port USB 2.0 Aluminum Hub In Stock £14.78
8M60 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.17
8M60 C2G USB Superbooster Extender Kit In Stock £36.55
8M60 C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £22.60
8M60 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
Ports: 50
Managed: Yes
POE: PoE+
Brand: NETGEAR
Price Range Ex VAT: 750 - 1000
