The NETGEAR 4G LTE Modem gives you a simple, LTE connectivity solution for your devices, avoiding disruptions in broadband when your fixed wire line goes down. Simply connect this modem directly to your router, switch or computer to provide an automatic 4G LTE or 3G/2G broadband backup connection with download speeds of up to 150 Mbps. It has a Gigabit Ethernet WAN port so that you can plug in your wireless router and share connection with all your Wi-Fi and wired devices. The NETGEAR 4G LTE Modem is also compact, convenient, and simple to setup.
Super-fast connectivity with 4G LTE & 3G
Get secure and super-fast 4G LTE connectivity with 3G/2G fallback for broadband failover. -
Wired connections
Gigabit Ethernet WAN port for connection pass-through. -
Better signal reception
Two connectors available to connect optional 4G/3G antennas for better signal reception.
- NETGEAR LB1110 - wireless cellular modem - 4G LTE
- Wireless cellular modem - Gigabit Ethernet
- Form Factor
- External
- Localisation
- Europe
- Max Transfer Rate
- 150 Mbps
- Mobile Communication Protocol
- GSM, UMTS, LTE, DC-HSPA+
- Power
- AC 230V
- System Requirements
- Apple MacOS X 10.6.8 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
- 12 cm x 9.9 cm x 3.1 cm
- 150 g
- Form Factor
- External
- Built-in Devices
- Led panel
- Localisation
- Europe
Modem
- Bus
- Gigabit Ethernet
- Connectivity Technology
- Wireless
- Max Transfer Rate
- 150 Mbps
- Antenna
- External detachable
- Antenna Qty
- 1
- Remote Management Protocol
- TR-069
- DMZ port, DHCP server
- 1 x 1000Base-T - RJ-45
- SIM Card Supported
- Regular (mini-SIM) x 1
- Cables Included
- 1 x network cable
- Included Accessories
- Power adapter
- Voltage Required
- AC 230V
- OS Required
- 12 cm
- 9.9 cm
- 3.1 cm
- 150 g
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
