Product
NETGEAR LB1110 Wireless Cellular Modem GSM, UMTS, LTE, DC-HSPA+
Quicklinx: CDWLWS00 Mfr#: LB1110-100EUS
The NETGEAR 4G LTE Modem gives you a simple, LTE connectivity solution for your devices, avoiding disruptions in broadband when your fixed wire line goes down. Simply connect this modem directly to your router, switch or computer to provide an automatic 4G LTE or 3G/2G broadband backup connection with download speeds of up to 150 Mbps. It has a Gigabit Ethernet WAN port so that you can plug in your wireless router and share connection with all your Wi-Fi and wired devices. The NETGEAR 4G LTE Modem is also compact, convenient, and simple to setup.
  • Super-fast connectivity with 4G LTE & 3G
    Get secure and super-fast 4G LTE connectivity with 3G/2G fallback for broadband failover.
  • Wired connections
    Gigabit Ethernet WAN port for connection pass-through.
  • Better signal reception
    Two connectors available to connect optional 4G/3G antennas for better signal reception.
NETGEAR LB1110 - wireless cellular modem - 4G LTE
Wireless cellular modem - Gigabit Ethernet
External
Europe
Max Transfer Rate
150 Mbps
Cellular Protocol
AC 230V
Apple MacOS X 10.6.8 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
12 cm x 9.9 cm x 3.1 cm
150 g
External
Built-in Devices
Led panel
Europe
Modem
Bus
Gigabit Ethernet
Wireless
Max Transfer Rate
150 Mbps
Cellular Protocol
Antenna
External detachable
Antenna Qty
1
Remote Management Protocol
TR-069
DMZ port, DHCP server
1 x 1000Base-T - RJ-45
SIM Card Supported
Regular (mini-SIM) x 1
1 x network cable
Power adapter
AC 230V
12 cm
9.9 cm
3.1 cm
150 g
0 - 90% (non-condensing)
CDWL C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
CDWL C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.20
CDWL C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.76
CDWL C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £45.82
