NETGEAR presents a great way to increase your network's capability without breaking your budget: the 16-port JFS516. This 10/100 Mbps Fast Ethernet switch provides expanded connectivity for small office networks so users no longer have to compete with each other for bandwidth.
All of the essential features - automatic speed and full/half duplex sensing, 200 Mbps throughput per port, Auto Uplink - are included, but at an economical price that a value-conscious business owner can not ignore.
- NETGEAR ProSAFE 16-Port 10/100 Fast Ethernet Switch JFS516v2 - switch - 16 ports - unmanaged - rack-mountable
- Switch - 16 ports - unmanaged
- Enclosure Type
- Rack-mountable
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100
- Power
- AC 120/230 V (50/60 Hz)
- 28 cm x 12.6 cm x 4.4 cm
- 0.92 kg
- Localisation
- Europe
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100
- Status Indicators
- Port status, power
- 16 x 100Base-TX RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 2.7 Watt
- FCC Class A certified, CB, CCC, UL 60950-1, C-Tick Class A, VCCI Class A
- Localisation
- Europe
- 28 cm
- 12.6 cm
- 4.4 cm
- 0.92 kg
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.07 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.55 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.44 |
C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue | In Stock | £40.80 |
