NETGEAR Insight Managed 8-port Gigabit Ethernet Smart Cloud Switch
TRADE IN AND SAVE
Quicklinx: D573WS00 Mfr#: GC110-100UKS
20 in stock
£49.15 ex VAT
£58.98 inc VAT
The NETGEAR VIZNTM GC110 is the first App Managed Smart Cloud 8-port Gigabit Ethernet Switch from NETGEAR with anywhere configuration and management. All you need is the NETGEAR Insight app for easy setup, monitoring and remote/cloud management of your VIZN Switches, VIZN Wireless Access Points, and Business-class ReadyNAS storage. The NETGEAR VIZN GC110 features 8 copper Gigabit Ethernet ports and 2 SFP Fiber ports for maximum flexibility and easy deployment in your network. With its remote cloud manageability, sleek design and fanless, silent operation, it's the most versatile switch on the market for any environment. Now you can setup, manage and monitor your network all from the palm of your hand and from anywhere in the world!
  • One-touch management
    App managed Smart Cloud Switch using the NETGEAR Insight app for one-touch installation, monitoring and management of all your GC110 and VIZN Switches and APs, no additional hardware needed.
  • Anywhere monitoring & management
    Smart Cloud remote management for unrivaled mobile management experience of your wireless network - anywhere, anytime, from the palm of your hand.
  • All-inclusive connectivity
    8-port Gigabit copper + 2-port Gigabit SFP fiber - All-inclusive connectivity with copper and fiber ports.
  • Smart switching
    Advanced L2 switching capabilities (VLANs, LAGs, QoS, ACLs, IPv6 support, IGMP snooping, multicast, RSTP, rate limiting, etc).
  • Modern design
    Clean, modern design and fanless, silent operation for flexible deployment in any environment, even noise sensitive (classrooms, offices, patient care).
NETGEAR Insight Managed GC110 - switch - 8 ports - smart
Switch - 8 ports - L2+ - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x Gigabit SFP
Performance
Fabric throughput: 20 Gbps , 1 Gbps copper latency (64-byte packets): 3000 µs , 1 Gbps fibre latency (64-byte packets): 2400 µs , Forwarding performance (64-byte packet size): 14.9 Mfps , 1 Gbps fibre latency (1518-byte packets): 2140 µs
ACL: 100 , VLANs supported: 256 , Priority queues: 8 , IGMP multicast groups: 512
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
HTTP, HTTPS, TFTP
Flow control, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, IPv6 support, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Dynamic ARP Inspection (DAI), fanless, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), dual firmware images, Strict Priority Queuing (SPQ), loop prevention, security lock slot (cable lock sold separately), 802.1x authentication, cloud managed, Type of Service (ToS), 1.5MB packet buffer, cable test, administrator's password, Link Aggregation, DNS client, protected ports, Weighted Round Robin (WRR)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az, UPnP
24.5 cm x 12.3 cm x 3.3 cm
740 g
United Kingdom
5-year warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
HTTP, HTTPS, TFTP
Encryption Algorithm
MD5, SSL, TLS, PEAP
Authentication Method
RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
1 Cortex-A9: 400 MHz
RAM
256 MB
Flash Memory
264 MB
Status Indicators
Power, status, link/activity/speed
8 x 10/100/1000 Base-T RJ-45 , 2 x 1000Base-X SFP
External power adapter
10.1 Watt
Wall mounting kit, foot pad set
MTBF
4,013,311 hours
BSMI CNS 13438 Class A, UL 60950-1 Second Edition, KCC, GB 9254-2008, K60950-1, GB4943.1-2011, RCM, BSMI CNS 14336-1, IEC 60950-1:2005 Second Edition, EN 61000-3-3:2013, FCC CFR47 Part 15 B Class A, EN 55024:2010+A1:2015, KN32, KN35, EN 55032:2012+AC:2013 Class A, AS/NZS 60950-1:2015, CISPR 32:2015 Class A, CAN/CSA-C22.2 No. 60950-1-07 Second Edition, ICES-003:2016, EN 61000-3-2:2014 Class A, VCCI-CISPR 32:2016 Class A, EN 60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013
United Kingdom
24.5 cm
12.3 cm
3.3 cm
740 g
Limited warranty - replacement - 5 years - response time: next business day , Limited warranty - power supply - 2 years , Technical support - 90 days
45 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
