NETGEAR Insight Gigabit Ethernet 802.11ac Wave 2 Wi-Fi 2.4 GHz Acess point
Quicklinx: F63TWS00 Mfr#: WAC540-10000S
Type: Radio access point
Connectivity: Wired
Protocol: IEEE 802.11ac Wave 2, IEEE 802.11a, Ethernet, IEEE 802.11b + 4 more
Compatibility: Mac, PC
  • IEEE 802.11n
28 in stock
£157.21 ex VAT
£188.65 inc VAT
The NETGEAR Insight Managed Smart Cloud Tri-band 4x4 Wireless Access Point WAC540 is a business grade Cloud Managed 11AC Wave 2 AP featuring MU-MIMO, Beamforming, Channel and Power management, and Airtime fairness with an aggregate throughput of 3 Gbps, Power-over-Ethernet (PoE).Compatible software includes: Insight Basic, Insight Premium, Insight Pro (for VAR Purchase only). Insight Pro items: NPR1SNG1, NPR1SNG3, NPR1SNG5, NPR10PK1, NPR10PK3, NPR10PK5, NPR25PK1, NPR25PK3, NPR25PK5, NPR50PK1, NPR50PK3, NPR50PK5, NPR100PK1, NPR100PK3, NPR100PK5.
NETGEAR Insight WAC540 - radio access point
Radio access point
External
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
Wall mounting kit, ceiling mounting kit
Power Over Ethernet (PoE) Supported
PoE+
24.153 cm x 24.153 cm x 4.021 cm
752 g
5-year warranty
Radio access point
24.153 cm
24.153 cm
4.021 cm
752 g
External
Wired
Line Coding Format
256 QAM
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, SSH
Frequency Band
Wi-Fi Rating
AC3000
Status Indicators
Power, LAN, 2.4/5 GHz
Load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Access Control List (ACL) support, LLDP support, cloud managed, Transmit Power Control (TPC), band steering, Backhaul Technology, guest access, Airtime Fairness, 4x4 MU-MIMO technology, opportunistic key caching (OKC), bridge mode
Encryption Algorithm
SSL, TLS, PEAP, TTLS, WPA, WPA2, WPA2-PSK, WPA-Enterprise
Authentication Method
Secure Shell (SSH), RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
2 x 1000Base-T (PoE+) - RJ-45
PoE+
External power adapter
25.5 Watt
Limited warranty - 5 years
Connectivity: Wired
Protocol: Ethernet
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
Brand: NETGEAR
Stock Status: In stock
