NETGEAR GS305 - V3 - switch - unmanaged - 5 x 10/100/1000
Quicklinx: FLWNWS00 Mfr#: GS305-300UKS
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: [N/A]
Managed: No
POE: No
38 In Stock
£16.55 ex VAT
£19.86 inc VAT
These NETGEAR home Ethernet switches provide an easy, reliable, and affordable way to expand your network connections in homes and small offices.
  • Efficient connectivity
    With five 1000Base-T RJ-45 ports, the NETGEAR GS305 switch facilitates high-speed wired connections, making it ideal for small office and home networks. Each port supports auto-negotiation, ensuring the best possible link speed and duplex mode, while auto-uplink adjusts for the different types of cables automatically.
  • Energy saving
    Incorporating Energy Efficient Ethernet (IEEE 802.3az) and a fanless design, this switch operates quietly and reduces power consumption, contributing to a lower cost of ownership and a more environmentally friendly office.
  • Enhanced performance
    The GS305 boasts a 10 Gbps bandwidth, allowing for seamless data transfer and handling high-demand network traffic. Combined with a 2K MAC address table and support for jumbo frames up to 9216 bytes, it ensures efficient network performance and management.
NETGEAR GS305 - v3 - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Bandwidth: 10 Gbps , Forwarding performance (64-byte packet size): 1448000 pps
Packet buffer size: 128
MAC Address Table Size
2K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), QoS, fanless, Energy Efficient Ethernet, SOHO, WRR
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
10.1 cm x 9.4 cm x 2.9 cm
250 g
3-year warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
2K entries
Jumbo Frame Support
9216 bytes
Status Indicators
Power, link/activity
5 x 1000Base-T RJ-45
External power adapter
2.15 Watt
Power Consumption Stand by
0.31 Watt
MTBF
3,831,422 hours
Plug and Play, IC Class B, VCCI, CB, FCC Part 15 B, LVD, RCM
10.1 cm
9.4 cm
2.9 cm
250 g
Limited warranty - 3 years
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 5
Managed: No
POE: No
Brand: NETGEAR
