NetGear FS728TLP 24 Port 10/100 Smart Switch
Quicklinx: 9TPNWS00 Mfr#: FS728TLP-100EUS
Type: Fast Ethernet
Ports: 24
Data Transfer Rate: 100Mbps
Managed: Yes
POE: PoE
£153.63 ex VAT
£184.35 inc VAT
The NETGEAR FS728TLP ProSafe 24-Port Smart Fast Ethernet PoE Switch provides 24 (twenty-four) 10/100BASE-T ports, 4 (four) 10/100/1000BASE-T ports, 2 (two) of which function as combo ports, and 2 (two) small form-factor pluggable (SFP) GBIC slots, both of which function as combo ports. Power over Ethernet (PoE) is supported on ports 1 through 12. The switchs management features include configuration for port and switch information, VLAN for traffic control, port trunking for increased bandwidth, and Class of Service (CoS) for traffic prioritisation.
Smart Management
The switch also provides the benefit of administrative management with a complete package of features to monitor, configure, and control the network. With the web management interface, you can view the switches many features and use them in a simple and intuitive manner. The NETGEAR FS728TLP switch management features include configuration for port and switch information, VLAN for traffic control, port trunking for increased bandwidth, and Class of Service (CoS) for traffic prioritisation. Initial discovery of the NETGEAR FS728TLPswitch on the network requires the Smart Control Center, a utility that runs on a computer.
Deployment and PoE
You can use the NETGEAR FS728TLP switch freestanding or rack-mounted in a wiring closet or equipment room. The switch is IEEE-compliant and provides low latency for high-speed networking. All port scan automatically negotiate to the highest speed. This capability makes the switch well suited for environments that have a mix of Ethernet, Fast Ethernet, and Gigabit Ethernet devices. In addition, all RJ-45 ports operate in half- or full-duplex mode. The maximum segment length is 328 feet (100 meters) over a Category 5 twisted-pair cable.
24 (twenty-four) x RJ-45 10/100 Fast Ethernet switch ports
4 (four) RJ-45 10/100/1000 Gigabit Ethernet switch ports
Autosensing and auto negotiating capabilities for all ports
Auto MDI/MIDX technology is supported on all ports
Full- and half-duplex functions for all 10/100/1000 Mbps ports
Store-and-forward transmission to remove corrupt packets from the network
Automatic address-learning function to build the packet-forwarding information table
Full-duplex IEEE 802.3x pause frame flow control
Standard 1U high, rack-mountable 19-inch chassis
Half-duplex back-pressure control
Per-port LEDs and system LEDs
Standard Warranty: Lifetime
NETGEAR ProSAFE FS728TLP - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
12 x 10/100 (PoE) + 12 x 10/100 + 2 x 10/100/1000 + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
100 W
Virtual interfaces (VLANs): 128 , Priority queues per port: 8 , Layer 2 multicast groups: 128
MAC Address Table Size
8K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, TFTP
Flow control, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, Weighted Random Early Detection (WRED), Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), LACP support, LLDP support, DHCP client, Energy Efficient Ethernet, 512KB packet buffer, Multicast filtering function, Class of Service (CoS), Denial of Service (DoS), 4MB packet buffer, 802.1x authentication, Type of Service (ToS), VoIP support, DiffServ Code Point (DSCP) support, cable test, administrator's password, Bridge protocol data unit (BPDU)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ab (LLDP), IEEE 802.3az
44 cm x 20.4 cm x 4.3 cm
2.92 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
PoE Budget
100 W
8K entries
Routing Protocol
Authentication Method
RADIUS
Status Indicators
Port transmission speed, power, PoE, link/activity, fan
12 x 100Base-TX RJ-45 , 12 x 100Base-TX RJ-45 PoE , 4 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
Internal power supply
124 Watt
Rack Mounting Kit
Included
MTBF
755,725 hours
cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, CISPR 22, EN50082-1, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A
Europe
Software Included
Drivers & Utilities
44 cm
20.4 cm
4.3 cm
2.92 kg
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
9TPN C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
9TPN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
9TPN C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.20
9TPN C2G 2m Cat6a Shielded Patch - Blue In Stock £7.49
Type: Fast Ethernet
Ports: 24
Managed: Yes
POE: PoE
Brand: NETGEAR
Price Range Ex VAT: 150 - 300
