NetGear EX7000-100UKS Nighthawk WiFi Range Extender AC1900 Dual Band
Quicklinx: B7Z4WS00 Mfr#: EX7000-100UKS
Type: Wi-Fi range extender
Connectivity: Wireless
Speed: 1900Mbps
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
Compatibility: Mac, PC
  • IEEE 802.11n
£89.28 ex VAT
£107.13 inc VAT
The NETGEAR Nighthawk AC1900 Wi-Fi range extender boosts your existing network range & speed, delivering extreme dual band Wi-Fi up to 1900 Mbps. The high-powered amplifiers provide extreme range, while the dual core 1 GHz processor enables maximum Wi-Fi performance. It works with any standard Wi-Fi router & is ideal for HD video streaming & gaming. Get the whole-home connectivity you need for iPads, smartphones, laptops & more.
Boost your existing WiFi
Extend dual band WiFi up to 1900Mbps & reduce interference
External antennas for better WiFi coverage & more speed
5 Gigabit Ethernet Ports - Connect a wired device like Blu-ray player, game console, or smart TV to your WiFi network
Two WiFi Modes - Extend existing WiFi connection or create a new AC WiFi access point
FastLane Technology - Use both WiFi bands to establish one super high-speed connection; ideal for HD streaming & gaming
Extend - Extreme Range & Performance
Extreme dual band WiFi speed - up to 1900Mbps
Dual Core 1GHz processor enables max WiFi performance
3 external antennas for max signal coverage
FastLane technology improves performance using both WiFi bands
Stream - Ultimate Connectivity
5 Gigabit ports to connect wired devices like smart TVs and game consoles
Access Point mode creates a WiFi hotspot using a wired Ethernet connection
USB 3.0 for up to 10x faster access to your stored media
DLNA server to play your media on TVs & game consoles
Access scheduling for parental controls
Mobile - Up To 100% Faster
Whole home WiFi coverage for your mobile devices
Print from an iPad or iPhone - Make any printer AirPrint compatible
Optimize your WiFi network with the WiFi Analytics app for Android
Web browser based settings accessible on most devices
WiFi Analytics App
How strong is your WiFi signal? Use the NETGEAR WiFi Analytics App & get advanced analytics to optimize your existing or newly extended WiFi network. Check your network status, WiFi signal strength, identify crowded WiFi channels & much more!
  • Extreme dual band Wi-Fi
    Get the whole-home connectivity you need for iPads, smartphones, laptops, & more. Boost the range your Wi-Fi network to every corner of your home for maximum Wi-Fi performance.
  • Boost your existing Wi-Fi
    Extreme range and speed for streaming with NETGEAR Nighthawk Wi-Fi range extender, with speeds up to 1900 Mbps and a 1 GHz dual core processor.
  • High power connection
    Ideal for HD video streaming and gaming, the NETGEAR Nighthawk AC1900 Wi-Fi range extender gives you powerful whole-home connectivity.
NETGEAR Nighthawk EX7000 - Wi-Fi range extender
External
United Kingdom
1 GHz
Ports Qty
5
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Vertical stand
25.2 cm x 17.4 cm x 3.1 cm
654 g
25.2 cm
17.4 cm
3.1 cm
654 g
United Kingdom
Processor / Memory / Storage
Processors Installed
1 GHz
External
Ports Qty
5
Wireless
Data Transfer Rate
1900 Mbps
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz, 5 GHz
Auto-sensing per device, parental control, Access Point operational mode, firmware upgradable, Wi-Fi Protected Setup (WPS), ReadySHARE, Push ā€˜Nā€™ Connect button, DLNA Media Server, FastLane Technology, AirPrint support
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
3
5 x 1000Base-T - RJ-45 , 1 x USB 3.0
Vertical stand
External power adapter
Speed: 1900Mbps
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Brand: NETGEAR
Price Range Ex VAT: 50 - 100
