The NETGEAR Universal Dual Band Wi-Fi Range Extender - Wall-plug Edition, simultaneously extends Wi-Fi coverage of an existing Wi-Fi network throughout your home so you can get better coverage for your Wi-Fi devices - on your patio or even in the backyard. The Wi-Fi Extender supports simultaneous dual band Wi-Fi coverage so you can connect devices on both 2.4 GHz and 5 GHz bands. While providing better Wi-Fi coverage, the Wi-Fi Extender also allows you to play music wirelessly over your network through any stereo or speaker in your home. By plugging in a USB printer into the USB port on the Wi-Fi Extender, you can make any wired USB printer accessible wirelessly from any Wi-Fi device and any room in your home.
- NETGEAR WN3500RP - Wi-Fi range extender - Wi-Fi
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Included Accessories
- Docking station
- OS Required
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7
- 12 cm x 7.9 cm x 4.2 cm
- 238 g
- 12 cm
- 7.9 cm
- 4.2 cm
- 238 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, status, WPS
- Auto-sensing per device, print server, Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button, FastLane Technology
- Encryption Algorithm
- WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED
- 1 x 100Base-TX - RJ-45 , 1 x USB 2.0 - Type A , 1 x audio
- Docking station
- RoHS, WEEE, CEC
- Power Device
- Internal power supply
- OS Required
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.02 |
