Your basket is empty
NetGear D6200 AC1200 Simultaneous Dual-Band ADSL 2/2+ Wireless-AC Router
Quicklinx: 8QYSWS00 Mfr#: D6200-100UKS
  • IEEE 802.11n
Wireless 802.11ac
Compatible with next generation WiFi devices and backward compatible with 802.11 a/b/g and n devices, this Netgear D6200 Wireless AC Router enables HD streaming throughout your home. This routers simultaneous dual band wireless technology offers speeds up to 1200Mbps (300+867) and avoids interference, ensuring top WiFi speeds and reliable connections.
Ease Of Use
The NETGEAR D6200 provides easy setup for iPad, tablets, smartphones & computers allowing you to surf the internet and stream music and videos in moments. The PUSH `N' CONNECT feature offers easy push button WiFi connections (WPS) for easy setup and convenience. Furthermore, the WiFi and Power On/Off button allows for convenient power savings.
NETGEAR ReadySHARE
This NETGEAR D6200 Simultaneous Dual-Band ADSL 2/2+ Wireless-AC Router also supports NETGEAR ReadySHARE Cloud service, which enables the creation of a highly secure private cloud for easily accessing and sharing files over the Internet. NETGEAR ReadySHARE Cloud keeps all your files stored securely at home on a USB external storage attached to the router, but available to transfer, edit or share anywhere, anytime remotely via your smartphone, tablet or PC.
Netgear Genie app (iOS and Android)
The Netgear Genie app provides easy installation from an iPad, tablet, computer or smartphone. It includes a personal dashboard, allowing you to manage, monitor, and repair your home network. Netgear customers can download the app at http://www.netgear.com/genie or from the Google Play or App Store.
Wireless speeds of up to 1200Mbps. 867Mbps using the 5GHz band, and/or 300Mbps on 2.4GHz
Simultaneous Dual band wireless for connecting 2.4Ghz 802.11n devices up to 300Mbps
Ultimate Range, wireless coverage throughout your home or office to connect your wireless devices
Four 10/100/1000 Gigabit RJ45 Ethernet ports offer ultra-fast wired connections
Easy to setup with the Netgear Push `N' Connect using Wi-Fi Protected Setup (WPS)
Free Genie app to make connecting devices and repairing your network simple (iOS or Android)
Multi-level Wireless Security Support: WPA2 (TKIP, AES), WPA-PSK (TKIP, AES), and WEP (128/64-bit)
NETGEAR D6200 - wireless router - DSL modem - 802.11a/b/g/n/ac - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2+
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
Firewall protection, auto-sensing per device, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Green Ethernet, ReadySHARE, Push ‘N’ Connect button, on/off switches
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
20.5 cm x 25.5 cm x 7.7 cm
654 g
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7, Windows 8
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac, RoHS, WEEE, CEC
RAM
128 MB
Flash Memory
128 MB
Communications
DSL modem
ADSL2+
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x ADSL2+
Aerial
Aerial
Internal
External power adapter
POTS filter
1 x network cable , 1 x phone cable
United Kingdom
Software Included
NETGEAR Genie
20.5 cm
25.5 cm
7.7 cm
654 g
8QYS C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
8QYS C2G 5m USB 2.0 A/B Cable - Black In Stock £4.24
8QYS C2G 2-Port USB 2.0 Manual Switch In Stock £16.25
8QYS C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.34
8QYS C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
8QYS C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.89
