Product
NETGEAR Arlo Table and Ceiling Mount
Quicklinx: B830WS00 Mfr#: VMA1100-10000S
Type: Security Accessory
Compatible With: Alexa, Google Assistant, SmartThings
3 in stock
£16.39 ex VAT
£19.66 inc VAT
Standard delivery Delivered within 3-5 working days
Get placement flexibility for your Arlo security cameras. Use freestanding on a table or secure it to the ceiling with included mounting screws. Simply snap on the camera onto the magnetic ball and aim it any direction you want.
  • Safe made simple
    Arlo makes it easy to keep tabs on what's happening. Setup is fast. And with the free Arlo mobile app, all it takes to tune in from wherever you are is a quick tap of the finger.
  • More cameras, more options
    It's so easy to add more cameras that you'll spend more time deciding where to put them than you will setting them up.
  • Live stream
    Use the Arlo app to stream live HD views, or rewind your cloud recordings to see what you missed.
  • Customize your system
    Effortlessly adjust your system to fit your routine, keep watch only when you want it to, and avoid false alarms.
Arlo camera mount
Camera mount
Placing / Mounting
Ceiling mountable, desk mountable, wall mountable
Camera mount
Placing / Mounting
Mounting Kit
Included
Magnetic closure, 360° head rotation
Compatible With: SmartThings
Brand: NETGEAR
Price Range Ex VAT: 0 - 50
