Arlo Security Light is wire-free so you can easily set one up around your home for security. Put one above the driveway or front porch without worrying about dangling wires and power outlets.
Arlo Security Light grabs attention from not only your eyes, but your ears as well. Get alerted to what's happening around your home even when you're not around.
The Arlo Security Light works intelligently by itself or paired with your Arlo security cameras. If your side gate light detects motion, it can trigger the Arlo camera around the corner to start recording.
Cover more, miss less
Arlo lights and cameras aren't attached to each other so they can go where they're needed most. And that's the beauty of it. They work amazingly together, even when they're apart. -
More coverage, better security
When you have your lights and cameras in different corners of your property, your motion detection area increases. -
Better battery life
The Arlo light and camera run on their own battery to work more efficiently and effectively. -
More ways to mix and match
The Arlo light isn't attached to a specific camera so you can pair it with any Arlo camera that best fits your needs. -
100% wire-free
Free of power cords & wiring hassles. Place it anywhere. -
Weather-resistant
It works indoors or outdoors in the rain, sun, or chill. -
Scheduling
Automate your light for when you are at home, work, or on vacation. -
Smart controls
Use the Arlo app to manage & automate your light from anywhere. -
Multi-colored LED light
Select from millions of colors for security or ambience lighting. -
Motion detection alerts
Get instant notifications sent to your smartphone or email.
- Arlo Smart - security light - LED - white
- Product Type
- Security light
- Light Source Type
- LED
- White
- Product Type
- Security light
- Weatherproof
Light Source
- LED
- Rechargeable
- Body Colour
- White
- Included Accessories
- Power adapter, battery, window decal
- UL, IC, FCC, IP65
- 10.2 cm
- 7.3 cm
- 6.1 cm
- 292 g
