NETGEAR Arlo Pro Plus Add-On Camera
Quicklinx: D9RHWS00 Mfr#: VMC4030P-100EUS
£209.01 ex VAT
£250.81 inc VAT
1080p HD lets you see everything that goes on at home in more brilliant detail than ever before. That means, if an intruder were to break into your home, Arlo's clear video quality can help you better identify the suspect.
Arlo Pro 2 has the flexibility to go wire-free thanks to its rechargeable battery, or stay plugged into power. When plugged in to an indoor power outlet, you unlock your security camera's advanced features, like Activity Zones and optional 24/7 continuous video recording.
  • Details make the difference
  • Get the best of both worlds
  • Come rain or shine
    Get security where you need it most, to watch over what you love the most. The IP65-certified Arlo Pro 2 is weather-resistant to stand watch for you from anywhere. Indoors or out, rain or shine.
Arlo Pro 2 VMC4030P - network surveillance camera
Network surveillance camera - fixed - outdoor - waterproof
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
7.93 cm x 4.86 cm x 7.05 cm
136 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Video Modes
1080p
Optical Sensor Type
CMOS
Focal Length Control
Fixed focal
IEEE 802.11n
Motion sensor, e-mail alerts, weatherproof, Push Notification, built-in siren, auto white balance, sound sensor, infrared-cut filter, night vision
Environmental Parameters (operating)
-20 °C - 45 °C
Audio Support
Wireless
7.93 cm
4.86 cm
7.05 cm
136 g
Camera
Colour - Day&Night - fixed - outdoor - waterproof
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Digital Zoom
8
Infrared LEDs
Infrared Distance
7.62 m
Video Capture
1920 x 1080
Image Sensor
CMOS
Lens Construction
Fixed focal
Horizontal Field of View (degree)
130
Network Interface
IEEE 802.11n
Magnet mount, window decal, screw kit
IP65
Power adapter
1 2440 mAh
-20 °C
45 °C
Brand: NETGEAR
Price Range Ex VAT: 150 - 300
