NETGEAR Arlo Pro Plus 3 Camera System
Quicklinx: D9RKWS00 Mfr#: VMS4330P-100EUS
£627.05 ex VAT
£752.46 inc VAT
When it comes to security, trust a Pro. The next level 1080p HD security camera with total flexibility.
  • 1080p HD quality
    Watch and record crisp HD video in more detail than ever before.
  • Sound and advanced motion detection
    Get instant notifications sent to your smartphone or email.
  • Activity zones
    Highlight areas in your camera's view where you want to receive motion and sound alerts.
  • 3-second look back
    Capture activity 3 seconds before a triggered event so you'll always know what happened, from start to finish.
  • Flexible powering options
    Use it wire-free with the rechargeable battery. Or plug it in to an indoor power outlet to unlock advanced features.
  • Rechargeable battery
    Long lasting, takes the expense out of security.
  • 2-way audio
    Listen in and talk back through the camera from your smartphone.
  • Night vision
    Turns on automatically in low light so you can see clearly, even in the dark.
  • Peace of mind anytime, anywhere
    1080p HD quality means you get videos with sharper details so you can see your home and everyone around it in more brilliant detail than ever before, day or night. No matter where you are.
  • Your world, just a tap away
    Stay in total control all the time. Whether you're using a smartphone, tablet, or computer, a click or two is all you'll ever need to check in.
Arlo Pro 2 VMS4330P - video server + camera(s) - wireless
System
Video server + camera(s) - wireless - IEEE 802.11n - 2.4 GHz
Camera
3 cameras - outdoor - night vision
System
Network Interface
IEEE 802.11n
Wireless Frequency Band
2.4 GHz
2-way audio, built-in microphone, built-in speaker, push notifications, infrared cut filter, motion detection, e-mail alerts, sound detection, 1080p HD video, weather-resistant, Smart Siren, geofencing
Package Content
Camera wall mount, power adapter, power cable, 2 window decals, rechargeable batteries
Network cable - 1 pcs.
Video Server
CPU
ARM Cortex A7
RAM
128 MB
Flash Memory
128 MB
Cameras
Quantity
3 cameras
Camera Type
Outdoor
Sensor
CMOS
Field of View
130°
Night Vision
Infrared LEDs
850
Infrared Distance
7.62 m
White Balance
Auto
-20 °C
45 °C
IP65
Details
Video server: 5.86 cm x 17.45 cm x 12.65 cm - 316 g , Camera: 7.93 cm x 4.86 cm x 7.05 cm - 136 g
Type: Home security and monitoring system
Type: Home security system
Compatible With: Alexa
Brand: NETGEAR
Price Range Ex VAT: 500 - 750
