NetGear AC785-100EUS AirCard 785 Mobile Hotspot
Quicklinx: B40GWS00 Mfr#: AC785-100EUS
Ensure the best speed and performance for Wi-Fi devices almost anywhere you go with the AirCard 785S mobile hotspot. It's sleek, compact and loaded with powerful features such as an integrated data usage meter, dual-band Wi-Fi and a long lasting battery.
  • Effortless connectivity
    With the NETGEAR AirCard AC785, staying connected while on-the-go has never been easier. This mobile hotspot supports a wide range of cellular protocols including LTE, HSPA+, EDGE, and GPRS, ensuring you have access to high-speed Internet wherever you are. Its wireless connectivity technology seamlessly integrates with your devices, providing a reliable Internet connection for all your needs.
  • Long-lasting performance
    Equipped with a lithium-ion battery, the NETGEAR AirCard AC785 is designed for extended use, ensuring you stay connected without constant recharges. Whether you're working remotely or streaming your favorite content, this mobile hotspot keeps you online longer.
  • Secure and simple setup
    Featuring Wi-Fi Protected Setup (WPS) and support for multiple SSIDs, the NETGEAR AirCard AC785 offers a secure and straightforward way to connect multiple devices to the Internet. Its built-in display and external form factor make monitoring and managing your network connections effortless.
NETGEAR AirCard AC785 - mobile hotspot - 4G LTE
Mobile hotspot
External
Mobile Communication Protocol
GPRS, EDGE, HSPA+, LTE
Mobile Band
LTE 800/850/900/1800/2100/2600 / HSPA+ 850/900/1800/2100
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Up to 10 hrs
11 cm x 6.9 cm x 1.66 cm
127 g
Mobile hotspot
External
Built-in Devices
Display
Modem
Wireless
Mobile Band
Antenna
Internal
Wireless
Wi-Fi Protected Setup (WPS), Multiple SSID support
1 x USB cable
Lithium Ion
Up to 10 hrs
11 cm
6.9 cm
1.66 cm
127 g
