Boost the WiFi coverage in your home by adding the NETGEAR EX3800 AC750 Simultaneous Dual-Band WiFi Booster/Range Extender. With speeds up to 750Mbps and an extra Ethernet port, you can connect to speed for gaming and streaming via WiFi or a wired connection. Convenient wall-plug design lets you discreetly place the range extender where you need it, while the new pass-thru design lets you keep access to your outlet.
Key Features
- Simultaneous dual band WiFi speeds of up to 750Mbps.
- Provides an extra outlet to power additional devices.
- Extend 2.4 and 5 GHz WiFi up to 750Mbps and reduce interference.
- FastLane Technology to establish super high-speed connections.
- Convenient wall-plug design with extra noise-filtered power outlet.
- Ideal for online gaming and HD streaming on tablets, smart phones and TV.
- Connect a wired device like a console or a smart TV to your WiFi network.
Boost AC750 Wi-Fi
Improve range and speed of your existing AC750 Wi-Fi network. -
Extra power outlet
Provides an extra outlet to power additional devices. -
Ethernet port
Connect a wired device like a game console or a smart TV to your Wi-Fi network. -
Simultaneous Dual Band Wi-Fi
Extend 2.4 & 5GHz Wi-Fi up to 750Mbps & reduce interference. -
External antennas
For better Wi-Fi coverage & more speed. -
FastLane technology
Use both Wi-Fi bands to establish one super high-speed connection; ideal for HD streaming & gaming.
- NETGEAR AC750 WiFi Range Extender EX3800 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- 6.4 cm x 4.45 cm x 11.4 cm
- 192 g
- 2-year warranty
- 6.4 cm
- 4.45 cm
- 11.4 cm
- 192 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 750 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, status
- Auto-sensing per device, Wi-Fi Protected Setup (WPS), Push āNā Connect button, FastLane Technology
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna
- External integrated
- Antenna Qty
- 2
- 1 x 1000Base-T - RJ-45
- Power Device
- Internal power supply
- Limited warranty - 2 years
