Product
NetGear AC750 WiFi Range Extender + Extra Outlet
Quicklinx: BYL7WS00 Mfr#: EX3800-100UKS
  • IEEE 802.11n
Boost the WiFi coverage in your home by adding the NETGEAR EX3800 AC750 Simultaneous Dual-Band WiFi Booster/Range Extender. With speeds up to 750Mbps and an extra Ethernet port, you can connect to speed for gaming and streaming via WiFi or a wired connection. Convenient wall-plug design lets you discreetly place the range extender where you need it, while the new pass-thru design lets you keep access to your outlet.
Key Features
  • Simultaneous dual band WiFi speeds of up to 750Mbps.
  • Provides an extra outlet to power additional devices.
  • Extend 2.4 and 5 GHz WiFi up to 750Mbps and reduce interference.
  • FastLane Technology to establish super high-speed connections.
  • Convenient wall-plug design with extra noise-filtered power outlet.
  • Ideal for online gaming and HD streaming on tablets, smart phones and TV.
  • Connect a wired device like a console or a smart TV to your WiFi network.
  • Boost AC750 Wi-Fi
    Improve range and speed of your existing AC750 Wi-Fi network.
  • Extra power outlet
  • Ethernet port
    Connect a wired device like a game console or a smart TV to your Wi-Fi network.
  • Simultaneous Dual Band Wi-Fi
    Extend 2.4 & 5GHz Wi-Fi up to 750Mbps & reduce interference.
  • External antennas
    For better Wi-Fi coverage & more speed.
  • FastLane technology
    Use both Wi-Fi bands to establish one super high-speed connection; ideal for HD streaming & gaming.
NETGEAR AC750 WiFi Range Extender EX3800 - Wi-Fi range extender
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
6.4 cm x 4.45 cm x 11.4 cm
192 g
2 years warranty
6.4 cm
4.45 cm
11.4 cm
192 g
United Kingdom
External
Wireless
Data Transfer Rate
750 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, status
Auto-sensing per device, Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button, FastLane Technology
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
External integrated
Antenna Qty
2
1 x 1000Base-T - RJ-45
Internal power supply
