NETGEAR AC2200 Tri-Band Wallplug Wi-Fi Extender
Quicklinx: D5BVWS00 Mfr#: EX7500-100UKS
Type: Wi-Fi range extender
Connectivity: Wireless
Speed: 2.2Gbps
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • IEEE 802.11n
More than 50 in stock
£109.68 ex VAT
£131.61 inc VAT
Nighthawk X4S AC2200 Tri-band Wi-Fi Range Extender provides speeds up to 2.2 Gbps while high-power internal antennas extend Wi-Fi range in hard-to-reach areas of your home. One Wi-Fi Name with any router uses the same Wi-Fi name as your existing Wi-Fi and provides seamless connectivity across router and extender as you roam throughout the house. Unlike other dual-band extenders, the Dedicated Wi-Fi Link helps establish an exclusive connection to the router that avoids automatic bandwidth reduction of extended Wi-Fi signals. Smart Roaming intelligently connects your mobile devices to the best available Wi-Fi for superior streaming as you move around your house.
NETGEAR Nighthawk X4S - Wi-Fi range extender
External
United Kingdom
1 x
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
8.382 cm x 7.62 cm x 16.104 cm
304 g
8.382 cm
7.62 cm
16.104 cm
304 g
United Kingdom
Processor / Memory / Storage
Processors Installed
1 x
External
Wireless
Data Transfer Rate
2.2 Gbps
Line Coding Format
256 QAM
Frequency Band
Wi-Fi AC Rating
AC2200
Wi-Fi Protected Setup (WPS), Push ā€˜Nā€™ Connect button, MU-MIMO technology, Tri-Band, Smart Connect, Smart Roaming
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac
Technical support - 90 days
Speed: 2.2Gbps
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Brand: NETGEAR
Price Range Ex VAT: 100 - 150
