NetGear AC1750 Smart WiFi Router
Quicklinx: BYLFWS00 Mfr#: R6400-100UKS
  • IEEE 802.11n
NETGEAR R6400 AC1750 Simultaneous Dual-Band WiFi Broadband Router will improve your WiFi speed and reliability, delivering speeds up to 1750Mbps. With poweful antennas and Beamforming+, this router offers the range and performance you need for large homes. Connect devices like Smart TVs and game consoles to the ultra-fast Gigabit Ethernet ports or connect a USB hard drive to one of two USB ports to create networked storage.
Key Features
  • AC1750 WiFi—450+1300 Mbps speeds
  • High-powered antennas
  • Beamforming+—Faster, more reliable connections
  • USB 3.0 port—Up to 10x faster USB hard drive access
  • Two USB ports—Wirelessly access and share USB hard drive and printer
  • Easy and secure remote access with VPN
  • ReadySHARE Vault Automatically backs up your PC to a USB hard drive connected to your router
  • NETGEAR genie App—Enjoy more of your connected home. Now with remote access.
Speed and WiFi Range
Everything you need for a fast, fast, fast connected home. Next generation 11ac WiFi with dual band technology provides whole home coverage with Gigabit wired & wireless connections. Extremely fast WiFi —Up to 450+1300 Mbps. Got range? Homes come in all shapes and sizes and with powerful amplifiers and antennas, the AC1750 Smart WiFi Router provides WiFi coverage no matter where you connect in your home. Ultimate range WiFi coverage throughout very large homes.
Reliability and Sharing
There’s nothing more frustrating than lost connections! With NETGEAR’s advanced features and best-in-class technology, you’ll reduce interference and enjoy more reliable WiFi connectivity. Sharing across your network is fun and easy. Anything from accessing stored photos and music to sharing a USB printer and keep everything safe by using the included FREE ReadySHARE Vault software for backing up Windows-based PCs.
Ease of Use and Security
Start enjoying your new WiFi router faster than ever. NETGEAR makes sure installation and management is simple and easy, so you can connect quickly and stay that way. The highest security across your network ensures your privacy and family is safe while online. Whether it’s preventing phishing and spyware or just limiting access for kids and household guests, NETGEAR has you covered.
  • Speed
    Everything you need for a fast, fast, fast connected home. Next generation 11ac Wi-Fi with dual-band technology provides whole home coverage with Gigabit wired & wireless connections.
  • Wi-Fi range
    Got range? Homes come in all shapes and sizes and with powerful amplifiers and antennas, the Smart Wi-Fi router provides Wi-Fi coverage no matter where you connect in your home.
  • Reliability
    There's nothing more frustrating than lost connections! With NETGEAR's advanced features and amazing technology, you'll reduce interference and enjoy more reliable Wi-Fi connectivity.
  • Ease of use
    Start enjoying your Wi-Fi router faster than ever. NETGEAR makes sure installation and management is simple and easy, so you can connect quickly and stay that way.
  • Security
    The high security across your network ensures your privacy and family is safe while online. Whether it's preventing phishing and spyware or just limiting access for kids and household guests, NETGEAR has you covered.
NETGEAR R6400 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.75 Gbps
Firewall protection, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, print server, IPv6 support, DFS support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), ReadySHARE, Push ‘N’ Connect button, 3T3R MIMO technology, on/off switches, Beamforming+, Circle Smart Parental Controls
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
19.1 cm x 6.5 cm x 19.85 cm
430 g
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.75 Gbps
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac, RoHS
RAM
256 MB
Flash Memory
128 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
External power adapter
1 x network cable
Software Included
NETGEAR Genie
19.1 cm
6.5 cm
19.85 cm
430 g
