The NETGEAR AC1600 smart Wi-Fi router is an incredibly fast router delivering high Wi-Fi and Gigabit Ethernet speeds. External antennas provide improved Wi-Fi coverage for larger homes. It avoids wireless interference, ensuring top Wi-Fi speeds and reliable connections. Ideal for applications such as lag-free multiple video streaming, multi-player gaming, ultra-fast speed and a secure and reliable connection to the Internet.
Wide Wi-Fi range
The NETGEAR AC1600 smart Wi-Fi router provides Wi-Fi connectivity throughout your home for all your Internet-enabled devices. -
Reliability
There's nothing more frustrating than lost connections! With NETGEAR's advanced features & technology, you'll reduce interference & enjoy more reliable Wi-Fi connectivity. -
Easy sharing
With NETGEAR, sharing across your network is fun and easy, anything from accessing stored photos & music. -
Ease of use
Start enjoying your device faster than ever. NETGEAR wants to make sure installation and management is simple & easy, so you can connect quickly & make sure you stay that way!
- NETGEAR R6260 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Auto-sensing per device, SPI, DoS attack prevention, IPv6 support, parental control, WPS, FTP server, ReadySHARE, reset button, DLNA support, guest access, Advanced QoS, Circle Smart Parental Controls
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- 23.551 cm x 15.076 cm x 5.45 cm
- 340 g
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
- Localisation
- United Kingdom
- 1-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Encryption Algorithm
- WPA-PSK, WPA2-PSK
- Wi-Fi Rating
- AC1600
- Processor
- 880 MHz
- RAM
- 128 MB
- Flash Memory
- 128 MB
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin mini-USB Type A
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- OS Required
- 23.551 cm
- 15.076 cm
- 5.45 cm
- 340 g
- Limited warranty - 1 year
