NetGear AC1200 WiFi USB 3.0 Adapter 802.11ac
Quicklinx: B22XWS00 Mfr#: A6210-100PES
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
20 in stock
£32.86 ex VAT
£39.43 inc VAT
Kickstart your Windows PC or laptop and experience fast WiFi technology with the Netgear A6210-100PES USB Wireless Adapter.
Ultimate speed and range
Extreme speed is just a USB port away with the A6210-100PES USB Wireless Adapter. Offering impressive speeds of up to 1200 Mbps with 802.11ac, it's ideal for online gaming, browsing, and you can even stream multiple HD videos.
Dual band technology reduces interference for better connections to more WiFi devices, resulting in fewer annoying signal drop outs and making it ideal for connecting larger homes.
Reliable connections
Connections are fast with high gain antennas for increased range and improved performance, and with USB 3.0 you can connect even faster than USB 2.0. A desktop dock allows for flexible placement for your convenience.
Speed, range and reliability are given a further boost with Beamforming+ technology, which helps lock in your signal.
Backward compatible
You don't need the latest technology to use this wireless adapter - even older Windows based desktops and laptops can benefit from fast internet speeds. The A6210 is backward compatible with USB 2.0 and 802.11 a/b/g/n devices.
Setup is quick and easy with Netgear genie included software and Push `N' Connect feature which lets you simply press the button to securely connect and you're ready to go.
Perfect for larger houses, you can enjoy faster online gaming, streaming and browsing with the Netgear A6210-100PES USB Wireless Adapter.
NETGEAR A6210 - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
9.3 cm x 3.14 cm x 1.445 cm
28 g
802.11ac
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
1-year warranty
Network adapter
External
SuperSpeed USB 3.0
Wireless
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Protected Setup (WPS), Push ā€˜Nā€™ Connect button
1 x USB cable (external)
Software Included
NETGEAR Genie
9.3 cm
3.14 cm
1.445 cm
28 g
Limited warranty - 1 year
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: NETGEAR
Price Range Ex VAT: 0 - 50
