NETGEAR 8Pt 10G/Multigigabit Unmanaged Switch
Quicklinx: D9Q7WS00 Mfr#: XS508M-100EUS
Type: 10 Gigabit Ethernet
Ports: 8
Data Transfer Rate: [N/A]
Managed: No
POE: No
Select:
£431.63 ex VAT
£517.95 inc VAT
The XS508M come with Copper Ethernet ports that provide either Fast Ethernet, 1-Gigabit, 2.5-Gigabit, 5-Gigabit or 10-Gigabit connectivity, as well as 1 SFP+ Fiber port with 1-Gigabit or 10-Gigabit connectivity. Each port automatically detects which speed is needed by the connected device and provides the adequate speed. Also, the new NETGEAR Multi-speed switch ports can be connected with regular Cat5E Ethernet cables, without the need to upgrade to Cat6 wiring, therefore reducing wiring costs and hassle.
NETGEAR XS508M - switch - 8 ports - unmanaged - rack-mountable
Switch - 8 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
7 x 10 Gigabit Ethernet + 1 x 10 Gigabit Ethernet / 10 Gigabit Ethernet SFP+
Performance
Bandwidth: 160 Gbps
Priority queues: 8
MAC Address Table Size
2K entries
Jumbo Frame Support
9KB
DiffServ support, store and forward, QoS, 128KB packet buffer, CoS, metal housing, 1 fan, EEE, WRR
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az, IEEE 802.3bz
AC 120/230 V (50 - 60 Hz)
32.8 cm x 16.9 cm x 4.32 cm
1.49 kg
United Kingdom, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
Bandwidth: 160 Gbps
Priority queues: 8
2K entries
Jumbo Frame Support
9KB
Status Indicators
Power, fan, link/activity/speed
7 x 10GBase-T RJ-45 , 1 x 10Gbit LAN RJ-45/SFP+
Internal power supply
39 Watt
Rack Mounting Kit
Included
MTBF
1145157 hours
Plug and Play, VCCI, BSMI, ICES-003, EN55024, AS/NZS 60950-1, UL 60950-1, KCC, KC, CNS 13438, EN 55024:2010, FCC CFR47 Part 15 B Class B, AS/NZS CISPR 32 Class B, CNS 14336-1, VCCI V-4/2012.04, VCCI V-3/2015.04 Class B, ANSI C63.4-2014, CISPR 32, EN 55032, EN 55032:2012+AC:2013 Class B, ICES-003:2016 issue 6 Class B, EN 61000-3-2:2014 Class B, EN 6100-3-3:2013, sDoC, CB 60950-1, LVD 60950-1
32.8 cm
16.9 cm
4.32 cm
1.49 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
50 °C
95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 8
Managed: No
POE: No
Brand: NETGEAR
