NETGEAR 7P AC5300 Vdsl/Adsl Mdm Rout
Quicklinx: CZPSWS00 Mfr#: D8500-100EUS
  • IEEE 802.11n
The Nighthawk X8 AC5300 Wi-Fi VDSL/ADSL modem router is the next wave in Wi-Fi. Four external active antennas plus four internal antennas amplify Wi-Fi range. Gigabit Ethernet ports means even more wired devices can connect and with port aggregation 2 ports can combine to increase maximum wired speeds.
  • Fast tri-band Wi-Fi VDSL/ADSL modem router
    Nighthawk X8 not only delivers the fast total Wi-Fi speeds, but also uses Smart Connect to ensure all of your Wi-Fi devices like smartphones, tablets, and laptops connect at the fast speed.
  • Dynamic Quality of Service
    Reduce buffering and lag while gaming or streaming. Dynamic QoS automatically recognizes different applications and devices and intelligently allocates bandwidth to important activities in your home.
  • Active antennas
    With four internal antennas and four external antennas, the X8 will enhance weak signals and reduce interference. Active antennas help improve Wi-Fi performance by amplifying Wi-Fi signals in the antenna itself, this avoids signal loss during transmission and noise insertion from the router board. Enjoy better Wi-Fi range, performance and fewer dead-spots with this active antenna technology.
NETGEAR Nighthawk D8500 - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem - 6-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2, ADSL2+, VDSL2
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Data Transfer Rate
5.3 Gbps
NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), FTP server, ReadySHARE, Push ā€˜Nā€™ Connect button, Beamforming+, MU-MIMO technology, Tri-Band, Smart Connect, ReadyCLOUD, Dynamic QoS, DLNA support, Dual Port Aggregation
31.6 cm x 26.4 cm x 7.4 cm
1.967 kg
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
Europe
Wireless router - 6-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Data Transfer Rate
5.3 Gbps
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
1.4 GHz
RAM
512 MB
Flash Memory
128 MB
Line Properties
Line Coding Format
1024 QAM
Communications
DSL modem
LAN: 6 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 3.0: 2 x 9 pin USB Type A
Aerial
Aerial
External detachable and internal
Antenna Qty
8
External power adapter
DSL filter
1 x network cable , 1 x phone cable
Europe
31.6 cm
26.4 cm
7.4 cm
1.967 kg
