NETGEAR 5P POE Gigabit Unmanaged Switch
Quicklinx: CZPHWS00 Mfr#: GS305P-100UKS
£49.74 ex VAT
£59.68 inc VAT
5 Gigabit Ethernet ports
4 PoE+ ports with 63W total power budget
Simple plug-and-play setup with no software to install or configuration needed
Supports desktop or wall mount placement
Silent operation ideal for noise sensitive environment
NETGEAR GS305P - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000 (4 PoE)
Power Over Ethernet (PoE)
PoE
PoE Budget
55.5 W
Fanless
3-year warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
55.5 W
Fanless
Status Indicators
Power, PoE, link/activity
4 x 1000Base-T RJ-45 PoE , 1 x 1000Base-T RJ-45
Plug and Play
Limited warranty - 3 years
