NETGEAR 4P Orbi Satellite
Quicklinx: CZQ3WS00 Mfr#: RBS50-100UKS
  • IEEE 802.11n
£169.43 ex VAT
£203.31 inc VAT
Orbi is an extremely simple and smart way to enjoy high-speed Wi-Fi in every corner of your home. Each add-on Orbi satellite easily expands your Orbi Wi-Fi system to cover an additional 2000 square feet with strong Wi-Fi signals. Tri-band Wi-Fi creates a dedicated wireless connection to your Orbi router and the Internet, so no matter how many devices connect you'll get maximum speed.
  • Better Wi-Fi everywhere
    Take any Wi-Fi device from room to room and Orbi follows with extremely fast Wi-Fi speeds.
  • Max Internet speeds
    Orbi uses Tri-band Wi-Fi to keep your Internet running at max speeds no matter how many devices connect.
  • Your home covered
    Add-on to your existing Orbi Wi-Fi system to expand your Wi-Fi coverage an additional 2000 sq.ft. with high-performance AC3000 Wi-Fi.
  • Growing with you
    Each add-on Orbi satellite expands your high performance Wi-Fi coverage an additional 2000 sq.ft.
NETGEAR Add-on High-performance AC3000 Tri-band WiFi Satellite - Wi-Fi range extender - Wi-Fi 5
Desktop
RAM
512 MB
Flash Memory
4 GB
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
17.03 cm x 7.89 cm x 22.58 cm
890.5 g
17.03 cm
7.89 cm
22.58 cm
890.5 g
Processor / Memory / Storage
RAM
512 MB
Flash Memory
4 GB
Desktop
Wireless
Data Transfer Rate
3 Gbps
Frequency Band
2.4 GHz, 5 GHz
MU-MIMO technology, beamforming technology, Circle Smart Parental Controls
Aerial
Antenna
Internal
Antenna Qty
6
4 x 1000Base-T - RJ-45 , 1 x USB 2.0
FCC
