NetGear 24PT GIGABIT Plus Switch
Quicklinx: 9SFBWS00 Mfr#: JGS524E-200EUS
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
£111.15 ex VAT
£133.38 inc VAT
Control and Configure Beyond Plug-N-Play Connectivity
Growing businesses demand and rely more on their network to carry out mission-critical business activities. Companies are putting more network traffic and applications such as VoIP phones and IP cameras on their Ethernet infrastructure. It needs the network intelligence to separate the voice and video traffic from data and prioritise them accordingly. However, companies do not necessarily have more money or better training to deal with complex managed switches. NETGEAR ProSAFE Plus Switches meet this growing need by providing fundamental network features that will help optimise the performance of business networks. On top of the plug-N-play Gigabit Ethernet connectivity, these switches also offer essential networking features such as VLAN, QoS, IGMP Snooping, Link Aggregation (LAG), rate limiting and traffic monitoring. NETGEAR ProSAFE Plus Switches are an exceptional value for businesses looking to add intelligence to their network beyond what unmanaged switches can provide.
Prioritise Voice/Video
With the ability to set up and configure QoS, these Gigabit Plus Switches can detect different types of network traffic and assign the desired priority to latency-sensitive traffic, such as voice and video. This helps improve the delivery quality of related applications such as VoIP, multimedia broadcasting and video conferencing.
IGMP Snooping for Optimised Multimedia Traffic Delivery
By listening in on the IGMP conversation between hosts and routers, the Gigabit Plus switch can maintain a map as to which links need which IP multicast streams. The Gigabit Plus switch therefore will be able to forward multicast traffic only to the links that have asked for them and cut multicast traffic from links that do not contain a multicast listener. Essentially, IGMP snooping helps optimise multicast performance at Layer 2 and is especially useful for bandwidth-intensive IP multicast applications such as IPTV.
ProSAFE Plus Switch delivers network monitoring, traffic prioritisation and VLAN
24 ports deliver up to 2000 Mbps of dedicated, non-blocking bandwidth per port
Simple, yet useful network set-up on top of plug-and-play connectivity
Gigabit speed with QoS, VLAN and network monitoring
VLAN support for traffic segmentation
Quality of Service (QoS) for traffic prioritisation
Auto "denial-of-service" (DoS) prevention
Troubleshoot connection issues via cable test
Loop prevention and broadcast storm controls
IGMP snooping v1, v2 and v3 support for multicast optimisation
Rate limiting for better bandwidth allocation
Port mirroring for network monitoring
Jumbo frame support
Box Contains
ProSAFE Plus Gigabit Switch
Rack-mount kit
Power cord
Quick Install Guide
Installation CD with Configuration Utility software
NETGEAR Plus JGS524Ev2 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Flow control, Layer 2 switching, auto-negotiation, VLAN support, DoS attack prevention, port mirroring, Broadcast Storm Control, Quality of Service (QoS), reset button, loop prevention
AC 120/230 V (50 - 60 Hz)
32.8 cm x 16.9 cm x 4.32 cm
1.4 kg
Europe
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Status Indicators
Port transmission speed, power, link/activity
24 x 1000Base-T RJ-45
Internal power supply
13.8 Watt
FCC Part 15 A, C-Tick Class A, KCC Class A, VCCI Class A, CCC Class A
Europe
32.8 cm
16.9 cm
4.32 cm
1.4 kg
50 °C
10 - 90% (non-condensing)
9SFB C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
9SFB C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.13
9SFB C2G 2m Cat6a Shielded Patch - Blue In Stock £7.45
Ports: 24
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: 100 - 150
