NetGear 24-Port Gigabit PoE Layer 2 Managed Switch
Quicklinx: 7YSHWS00 Mfr#: GSM7224P-100NES
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: Yes
POE: PoE+
£513.59 ex VAT
£616.30 inc VAT
IP telephony, Wireless or Video-Surveillance deployments may require higher PoE+ density in wiring closets. This 24-port PoE+ platform is 802.3af full power – with supplemental 802.3at full power capacity – yet affordable when compared to typical competitive solutions with even less PoE budget. When associated to GSM7212F, PoE deployments can be much Smarter with the right number of PoE ports – whenever and wherever you want.
  • Powerful
    Full 24 10/100/1000 ports and a non-blocking design provide wire speed throughput and maximum bandwidth for the most demanding network environments. The Layer 2 management features optimize bandwidth throughout the network - delivering Gigabit performance to systems, applications, and services. Take advantage of forwarding rates up to 71.4 million pps, and a switching capacity of 96 Gbps.
  • Easy to use
    Move up to Gigabit power in minutes. Use either of these solutions as a managed switch out of the box - just plug and play! All ports are auto-negotiating and support Auto Uplink technology. Choose from two easy-to-use management interface options - Web interface or a command line interface available through console or telnet. Comprehensive remote administration capabilities reduce the need for on-site administration.
  • Manageable
    Meet your management needs with SNMP (v1, v2c and v3), RMON, Command Line Interface (CLI) and completely redesigned Web-based GUI, ProSafe Control Center. Advanced features include up to 512 VLANs, DiffServ traffic prioritization and 802.1p (QoS) for Voice over IP services (VoIP), broadcast storm protection, RADIUS, 802.1x, port trunking, Rapid Spanning Tree, and link aggregation.
  • Outstanding
    These products offer Layer 2 management and full Gigabit power at a compelling price. Use at the edge to improve workgroup connections, or at the core to upgrade a Gigabit Ethernet backbone - now you can afford the power your network deserves.
NETGEAR ProSAFE GSM7224P - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x shared SFP
Power Over Ethernet (PoE)
PoE+
Performance
Switching capacity: 48 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
VLAN support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, PoE+, IPv4 support, Link Aggregation Control Protocol (LACP), DHCP client
IEEE 802.3af, IEEE 802.1x, IEEE 801.1p
44 cm x 20.5 cm x 4.3 cm
3.7 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
8K entries
Jumbo Frame Support
Max Units In A Stack
8
Routing Protocol
Static IP routing
Authentication Method
RADIUS, TACACS+
24 x 10Base-T/100Base-TX/1000Base-T RJ-45 PoE+ , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x USB , 4 x SFP (mini-GBIC) - SFP
Internal power supply
38.5 Watt
MTBF
239,032 hours
44 cm
20.5 cm
4.3 cm
3.7 kg
7YSH C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
7YSH C2G 5m USB 2.0 A/B Cable - Black In Stock £5.24
7YSH C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.51
7YSH C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.71
7YSH C2G USB Superbooster Extender Kit In Stock £39.76
Ports: 24
Managed: Yes
POE: PoE+
Brand: NETGEAR
Price Range Ex VAT: 500 - 750
